Error: EventSystem: in script_time_Besparing: [string "-- Slaapkamer ..."]:49: field 'day' missing in date table Topic is solved
remb0
Post by remb0 »
I'm busy with a cost saving script but I got:
2016-05-23 21:35:00.368 Error: EventSystem: in script_time_Besparing: [string "function timedifference(s) ..."]:9: field 'day' missing in date table
I think it is not in my script because I changed the code a lot (now it's back to the basis and doesn't make sense, but still got the error.
Is it a domoticz bug in the event system?
my device is working well:
11 RFX 0A2FEA6 12 Slaapkamer Lighting 2 AC Off 6
the script.
 year = string.sub(s, 1, 4)
 month = string.sub(s, 6, 7)
 day = string.sub(s, 9, 10)
 hour = string.sub(s, 12, 13)
 t1 = os.time()
 return difference
--		package.path 	= package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
--		My 				= require('MyFunc')
	-- Variable
		Script		  	= 'Besparing'						--
		Version       	= 1							--
		Notifications 	= uservariables["Notifications"] -- On/Off
		minuten_toegestaan	=	15 -- aantal minuten 180 = 3 uur
		StateDevice 	= 'Iemand_thuis'
		TH_Hour1        = 8		-- Treshold hour
		TH_Hour2        = 10		-- Treshold hour
		Nu_Hour			=tonumber(os.date('%H',time))
		Debug = 'Y'
		if ((Nu_Hour >= TH_Hour1) or (Nu_Hour <= TH_Hour2)) then Res_Hour=1   	else Res_Hour=0  end
	--	if (otherdevices['Slaapkamer'])  == 'On'   	        then Slaapkamer=1  	else Slaapkamer=0 end       -- omgedraait omdat het ook DO set dimmer level to 80% kan hebben ipv on.
	--	if (otherdevices['Gang']) 		 == 'On'	        then Gang=1   	    else Gang=0 end
		if (otherdevices['Iemand_thuis']) 		 == 'On'	    then Aanwezig=1   	else Aanwezig=0 end
--		TDiffGang		= My.Round(My.TimeDiff(os.time(),LastChange_Gang)/60,0)
--		TDiffSlaapkamer = My.Round(My.TimeDiff(os.time(),LastChange_Slaapkamer)/60,0)
	--logging
			print ('______________________________________________________________________')
			print('<b style="color:Blue"> '.. Script .. ".......v" .. Version .. "..Debugging=  " .. Debug .. '</b>')
			if (otherdevices['Bespaar_modus']) == 'Off' then 	print (".  Besparing wordt niet toegepast. ") 	goto done end
		if Debug == 'Y' then
		    --print ( ".  " .. Aanwezig .. " - Iemand thuis? " )
			-- print ( ".   Slaapkamer :    " .. TDiffSlaapkamer .. " minuten geleden naar: "  .. (otherdevices['Slaapkamer']) )
	-- Binnen gestelde tijd
--	commandArray['SendNotification']='Bespaaralert!#Gang staat al ' .. minuten_toegestaan .. ' minuten aan!#0#pushover'
--		if ((Aanwezig == 0) and (IetsAan >= 1))  then
--		    print(".  Niemand thuis terwijl" .. TDiffSlaapkamer .. " aan stond.")
--		    commandArray['SendNotification']='Bespaaralert!#Niemand aanwezig en devices aan!#1#pushover'
--		    commandArray['Alles']='On'
--        end
        --get status of all sensors
--if the sensor is dead for more than 1 day output the name of that sensors
for i, v in pairs(otherdevices) do
  timeon = 86400  -- 1 dag in seconden
  tc = tostring(i)
print("Alive: " .. tc .. " ");
     difference = timedifference(otherdevices_lastupdate[tc])
     if (difference > timeon) then
        tempdiff = tostring(difference)
        --remove garbage from the output, only report nodes that has not update for more than 1 day.
        v = i:sub(1,2)
        v2 = i:sub(1,4)
        v3 = i:sub(1,6)
        v4 = i:sub(1,17)
        if ( (v ~= 'IP') and (v2 ~= 'Talk') and (v3 ~= 'Tunein') and (v4 ~= 'Living Room - Hub') ) then
        print("Dead: " .. tc .. " : " .. difference);
::done::
FritzzJan
Re: Error: EventSystem: in script_time_Besparing: [string "-- Slaapkamer ..."]:49: field 'day' missing in date table
Post by FritzzJan »
Hello remb0,
I did some testing, and find out that the loop "for i, v in pairs(otherdevices) do" sometimes gives you an emty record.
If you pass an emty string to the timedifference function you get the "field day missing" error.
So your program is ok and you can go on testing if you check on an emty string.
It looks like a Domoticz error in the otherdevices function.
Good luck with the testing of your program!
remb0
Post by remb0 »
I have more then 1 devices that gives a nill. only I don't know how to filter them out properly..
do you have a hint?
FritzzJan
Post by FritzzJan »
This is a quick and dirty solution:
    tc = tostring(i)
    if (tc == "") then
        print ("nil value")
            v1 = i:sub(1,2)
            v2 = i:sub(1,4)
                v3 = i:sub(1,6)
            v4 = i:sub(1,17)
            if ( (v1 ~= 'IP') and (v2 ~= 'Talk') and (v3 ~= 'Tunein') and (v4 ~= 'Living Room - Hub') ) then
remb0
Post by remb0 »
Thanks I have a virtual text sensor that had no update or value yet.
solved.
emme
Domoticz version: latest
Post by emme »
Hi...
I got a similar issue....
the problem is a fake device... and cannot understans what are these :(
they are not available in the device tab, not in the used ones...
do I have to remove them straight from the db?!
"We always done this way"
mjdb
Domoticz version: all beta
Post by mjdb »
There can be several causes that the input for this function is invalid. The error-message "day is missing" is not helpful.
I modified the function with some data-checking. An error shows also what is wrong.
Besides that I renamed the function to "SecondsSince", but that is a personal preference.
  function SecondsSince(s)
    if (s == nil) then
      print('ERROR: Function SecondsSince got nil for Time')
      return 0
      if  (year > '2000') and (year < '2050')
      and (month >= '01') and (month <= '12')
      and (day >= '01') and (day <= '31')
      and (hour >= '00') and (hour <= '23')
      and (minutes >= '00') and (minutes <= '59')
      and (seconds >= '00') and (seconds <= '59') then
        t1 = os.time()
        return tonumber(difference)
        print('ERROR: Function SecondsSince got invalid input: ' .. s)
        return 0
  end -- SecondsSince
2 x Domoticz on Raspberry Pi; 2 x RFXtrx433; Aeotec Z-Stick
KlikAanKlikUit ICS-2000 as Relay
Aeotec MultiSensors 6; Danfoss Z Thermostats 014G0013; Kaku Switches, Z-wave Switches
