Stop Button on blinds
Posted: Sunday 22 May 2016 10:44
by mihadongle
Hallo why is on the setup mask of the venetian blinds eu no stop action? That would make its easy to stop the blinds! There is only on and off action!
Re: Stop Button on blinds
Posted: Sunday 22 May 2016 10:47
by gizmocuz
Your talking about a blind, should be set to blind, and should have Open/Close (at least), and your talking about On/Off
Please post a screenshot of the widget
Posted: Sunday 22 May 2016 11:20
by TAA
It is true that the stop button for venetian blinds does not do anything, but if you are opening the blinds and want to stop them at some point you just press the open button once more, and they will stop. Same goes for the close action. This works the same for both the blinds option and the venetian blinds (EU) option.
Now, from the apps its a different story. When using the Dromotica app by Sebastiaan Schimmel both the Blinds and the Venetian blinds option works correctly, but when using the Domoticz for Android app the Blinds options does not work at all.
For reference I'm using Nexa EJLR-1000 to control my screens (not blinds) but controller-module is for all motorised opening and closing.
Posted: Sunday 22 May 2016 12:05
by mihadongle
My homematic is self made with esp12wifi modules. I control the blind with ip commands. Set pin.. To 1 or to 0.i have make my own pcb for control. When i but twis to on then set my pcb it twis to 1! I need also so a action like on action where i can write the ip command in it.
Best regards michael
Posted: Saturday 01 October 2016 12:56
by gilzin
hi
how did you add a stop button in between?
