Roller shutter obstacle detection
Posted: Saturday 21 May 2016 21:26
Question 1:
I would like to implement an obstacle detection on an existing roller shutter.
My idea is to use the current consumption measuring to detect the obstacle(unless this function is already implemented in the module). I compare the percent opening+current with the reference current/opening. In case of too large deviation, the shutter stops.
Is this feasible?
What would you recommend for this
- QUBINO "Flush shutter" V2 ZMNHCD1
- Fibaro FGR-222 "Roller Shutter 2"
- Other module
- Change the motor with an obstacle detection motor (for example: Somfy ILMO)
Question 2(almost the same-different situation)
I would like to buy a new roller shutter for another windows.
What do you recommend:
- Standard roller shutter and same Z-Wave module as question 1
- Somfy ILMO motor with obstacle detection(can you give a z-wave module for this?)
Is this feasible?
- Other module
