Aeotec Z-Stick problem
Posted: Saturday 21 May 2016 10:38
by esteen
I have Domoticz running on Linux Debian and have encountered a problem.
Initially it seems like the stick worked in Domoticz but after that I added my first Z-Wave product to the stick it stopped working and the log in Domoticz says driver failed.
When I took it out of the server the button didn't work either and it stopped responding total.
I made a reset and after that I can pres the button but as soon as I put it back in the server and takes it out again it'seems dead.
Anybody else that have had the same problem?
Regards,
Mats
Re: Aeotec Z-Stick problem
Posted: Saturday 21 May 2016 11:30
by raym
Assuming the Z-Stick isn't faulty... you normally need to disable OZW (under hardware settings) before removing from your server. Otherwise, you'll run into problems like this.
Posted: Saturday 21 May 2016 15:47
by esteen
Ok, is that done by deactivating the Z-Stick or is it something else?
Posted: Sunday 22 May 2016 12:28
by raym
No, that's correct. Go to Setup | Hardware and select your controller. Then disable the "Enabled" check box before unplugging. Re-enable it once you've plugged it back in.
Posted: Sunday 22 May 2016 13:56
by esteen
Ok, i have tried that but it didn't work.
I re-insalled debian from scratch and then OZW and Domoticz.
But as soon as start Domoticz i get Driver Failed.
See pictures.
Anybody that have seen the same problem on Debian?
Posted: Tuesday 21 June 2016 7:48
by Kerneldomoticz
I hope i'm not coming in too late ... even if your last post is from a month ago ...
ok i did a fresh install last week with the same device as you the Zstick GEn5 from Aeotec.
First of all read this page :
https://www.domoticz.com/wiki/PersistentUSBDevices
then focus here :
AeoTec Z-Stick
Gen5: SUBSYSTEM=="tty", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="ttyUSB-ZStick-5G"
ok read carefully everything and now check your 2nd screenshot your Zwave is set on port /dev/ttyACM0 which is wrong from my experiences.
when i did the reinstall i did it like i did fo rmy zwave.me GPIO card ... i was wrong the corect way is in the Wiki page i sent you and like this it will work. no more driver error after i followed the wiki page.
Hope it will help you.
Cheers,
Flo
