How to interpret the Zwave Mesh diagram ?
Posted: Friday 20 May 2016 9:44
by oliviers
Here's an extract of my Zwave mesh diagram (focused on node 5):
I have the following questions:
1. Sometimes, nodes are interconnected by a wide strip (like 5 and 2, or 7 and 5,
for example), sometimes by a pointer (like 1 to 5, for example). Is there a different meaning between these two symbols ?
2. What does the little parabole (anchored to the middle of node 5) mean ?
Everything is working fine for me, but I'm just wondering ... If someone knows ...
Oliviers
Re: How to interpret the Zwave Mesh diagram ?
Posted: Friday 20 May 2016 13:16
by Kerneldomoticz
this is a good question , i'm interested by an explanation ! ;)
Posted: Friday 20 May 2016 18:43
by Egregius
Well, you're lucky to even see the difference in thickness :P
Also like to know the difference in colors etc.
Posted: Friday 20 May 2016 18:55
by gizmocuz
There is no 'difference' in colors, its just a color, assigned by the graph (new node a new color, thats all)
When you 'hover' with your mouse on a node, you will see the which nodes that 'hovered node' can see
For example, if you hover over 5, you will see it can see/reach node 1, 2 and 7 (might be more, can not tell from this screenshot)
Some nodes are out of range of the controller (node 1), but can reach for example another node, that is able to reach 1, so that node will act as a repeater.
Best to go to amazon and buy the zwave book
Posted: Friday 20 May 2016 19:57
by Derik
Egregius wrote:Well, you're lucky to even see the difference in thickness :P
Whow.....
Did you win the jackpot... :-)
Posted: Friday 20 May 2016 20:06
by oliviers
Well, my screenshot was done after I hovered on node 5 to simplify the diagram ....
Posted: Friday 20 May 2016 20:44
by mvveelen
I think the thickness of the lines or the numbers is random and doesn't really mean the connection is better or worse?
But nice to read along. Maybe there are some other things to mention here which I didn't know yet.
Posted: Friday 20 May 2016 21:36
by oliviers
Yet another question... Why are some sectors wider than other ones ? Does it mean anything ?
In my screenshot (see above), sectors 1 and 7 are wider than the others, f. ex.
This is also the case of the other screeshots shown in this thread.
Posted: Friday 20 May 2016 21:43
by Derik
Something with groups..
And:
https://en.wikipedia.org/wiki/Z-Wave
Something with the network integration....
more is better..
Posted: Saturday 21 May 2016 11:09
by Bikey
It certainly suggests that it a graph is wider it has better reception. I have noticed that without changing the configuration the thickness actually can change over time. Usually after first inclusion it starts with thin lines that get bigger overnight.
So it looks like it might present something like the signal to noice ratio.
I can also imagine that there is a difference between incoming and outgoing signals?
Any programmer that can verify this by looking at the code?
Posted: Sunday 22 May 2016 12:18
by oliviers
Dear Gizmocuz,
Amazon shows 30+ books on Zwave when I search on that topic.... Some of them being quite expensive ...
Which one would you recommand ?
Oliviers
Posted: Monday 30 May 2016 14:39
by Egregius
I don't think the network heal function does anything on the connected devices.
I moved 2 fibaro wall plugs to 2 meters and in clear sight of the controller and whatever I do they don't connect directly.
How can I update the neighbours without ex-/include?
Posted: Monday 30 May 2016 17:32
by Derik
Egregius wrote:I don't think the network heal function does anything on the connected devices.
What are the polling settings of your usb controller?
And push the button on your device a few times..[ wake up ]
Posted: Monday 30 May 2016 17:42
by Egregius
What has polling to do with neighbours and routing?
I moved Fibaro Wall plugs, they're always awake.
Posted: Monday 30 May 2016 17:47
by Derik
Egregius wrote:What has polling to do with neighbours and routing?
I did set my polling time shorter on my Aeon USB.
And sinds that time i did not lose my devices...
Posted: Monday 30 May 2016 17:51
by mvveelen
Having the same issue over here. Nodes within 1 mtr from the controller are connecting with the repeater which is at 4 mtrs from the controller. This repeater connects to other devices etc. I would like to reroute everything too, but automatically, not making the routes myself.
FYI, the polling on my controller is set to 120. Don't know what that has to do with this, but you asked it ;)
Posted: Monday 30 May 2016 22:32
by Egregius
I don't lose connection, they're are just not linked directly to the controller. Not even after moving them to 2 meters and doing all sorts of commands in Domoticz and OZWCP.
I'm just wondering how I can rebuild the known neighbours without exlude and include.
Posted: Monday 30 May 2016 23:59
by raym
It might be interesting to enable logging and attempting a heal again. It may reveal some clues as to what's going on.
I also think it's worth posting this question on the OZW forum. There may be a genuine bug with the network heal function.
Posted: Sunday 24 July 2016 11:09
by Olgmo
I have a node that is not connected to other nodes in the diagram, but it works OK.
How is that possible?
Now long does it take for the diagram to update to correct network?
