info
Artic1980
info
Post by Artic1980 »
Hello to all
I wanted to ask if there is a way to control a relay through a esp01 connected on another wifi network
Thank
woody4165
Re: info
Post by woody4165 »
Yes, if the relay is connected to an esp that is connected to another wifi network and you have ddns on this wifi and opened the port on that router you can.
Is it secure?
Artic1980
Re: info
Post by Artic1980 »
so you need a dns on serves and I and a dns on the second toe on the IP network that the esp ?
right?
I need to open the gate of the house which is close to the corporate network and away from home
thank
toreandre
Re: info
Post by toreandre »
There is many ways of doing this. You can set up port forwarding in your router to direct traffic from the internett to the correct unit on your homenetwork.
You can open up your domoticz to the internett.
You can use a mqtt server.
You can set up something like Telegram to send commands to your domoticz.
You can use an android device with tasker to react on emails etc and executes the gpio on the esp.
Or you could automate the unit if possible, so you dont need to do anything from work.
