EvoTouch shortcuts (e.g. Away, Economy, etc) not functioning and EvoTouch not updating
thijsvdb
Post by thijsvdb »
My setup is:
- Raspberry Pi 2 with the latest version of Domoticz 4834.
- Evohome Wifi Thermostat (ATC928G3000)
- 3 rooms with HR92 valves
I have followed the steps on the Evohome Docmoticz https://www.domoticz.com/wiki/Evohome#S ... for_RFG100.
Situation:
- EvoTouch and the 3 rooms are available in Domoticz.
- Temperatures are being updated every minute.
- EvoTouch is not being updated.
I have the following issue:
- The EvoTouch does not update (where the rooms are being updated every minute).
- The shortcuts (like switching to Away, Economy) does not work. Nothing happens.
Any ideas on how to set this up so that I can use the EvoTouch shortcuts and that this gets updated every minute like the rooms?
thijsvdb
Re: EvoTouch shortcuts (e.g. Away, Economy, etc) not functioning and EvoTouch not updating
Post by thijsvdb »
I did not.. I will wait for this to become available. Thanks!
thijsvdb
Post by thijsvdb »
gordonb3 wrote:As an alternative you could hack your evohome scripts. The problem is caused by the device IDs having one digit too many. You can hard code these in the scripts and use some search-and-replace functions to let them communicate a smaller ID with Domoticz.
I read your comments on other posts and see that this is not something that requires some hacking indeed. I will have to get my head around that.
Erwinvos72
Post by Erwinvos72 »
Hi Gordon,
you helped me in my own post already but i am still stuck with the updating part from my evohome.
Can you tell me where to look in the scripts and change the number you are talking about?
