Hello guys,
I like to create a number of virtual switches using JSON so to have IDX of switch selected by me. I search forum but no post found. Also wiki describes on the way to create virtual sensors but not virtual switches.
Is there any way to perform it even using a console script? Please help!
Add new virtual switch using JSON Topic is solved
korniza
- Domoticz version: V3.6028
>>>> Google Home <<<<<
- Egregius
- Domoticz version: v2024.7
Re: Add new virtual switch using JSON
Use developer mode of your browser while adding a switch.
Don't think you can choose the idx.
- Egregius
json.htm?type=createvirtualsensor&idx=2&sensorname=test&sensortype=6-
korniza
Thank you for! It does work!Egregius wrote:idx is the idx of the dummy hardware.Code: Select all
New device was created is not assigned to any hardware (it appeared on devices as ? unknown hardware). Can I "move" it to an exist hardware or build via JSON a hardware and assign this orphan device?
The reason I ask them is that I like to create a script to replicate some of my hardware to another (backup) domoticz. It is a painfull situation performing by hand and always have the same IDX for particular sensors.
>>>> Google Home <<<<<
- Egregius
I assume you have the dummy hardware installed and used that idx in your url?
If it's only for backup I would create a script that copies the records directly from/to the database.
korniza
If it was for the settings, I use the database backup/restore process. BUT is it for specific devices/sensors.
>>>> Google Home <<<<<
