Domoticz with PTZ cameras
Posted: Thursday 12 May 2016 11:24
by stuiow
Hi all.
Does anyone know if there is a camera (or even the function within Domoticz) that will allow you to setup PTZ points? Then when an action (for example, door bell pushed) the camera is sent to that point/location and starts recording or takes shots for a period of time?
I have a cheap outdoor PTZ that is a bit basic and would like to upgrade it, but unsure what to go for.
Cheers,
Stuart
Sent from my SM-G925F using Tapatalk
Re: Domoticz with PTZ cameras
Posted: Thursday 12 May 2016 20:11
by pepijn
There is no native support for PTZ, it's also not easy to build since every Chinese factory has a sort of own standard. (Except if you use ONVIF but this isn't always implemented correctly)
I use the selector switch for this purpose and added the different preset to the switch, using a http command to set the camera to the preset.
Posted: Thursday 12 May 2016 20:12
by stuiow
Probably easier to get multiple cheaper I cameras then.
Posted: Thursday 12 May 2016 21:34
by Egregius
Isn't a pi with camera and pan/tilt good for that?
