Wake up switch/;light
Posted: Friday 06 May 2016 15:15
by Joerideman
I'm trying to make a wake up light but I would like a simpler solution. I want a wake up switch, that lets me set the time from the frontpage and then activate it.
I would also like to expand the normal timer page with the following option:
* the ability to start an event 30 minutes before or after set Time. I don't want to program this in Domoticz every time I want to add a wakeup feature to a light. A bit like the "start before sunset" option.
I can make my nodes in such a way that they handle the intelligence behind it, as long as it gets a start signal.
So...
On the dashboard a switch had two options, set the wakeup time and a enable button.
Re: Wake up switch/;light
Posted: Saturday 07 May 2016 4:28
by Thomasdc
you own an android phone?
otherwise just check out 'Tasker" , you can do great thigs with it..
when your alarm on your phone goes off it sends an signal to domoticz,
no special alarm app needed, just the standard alarms in your phone! nothing else to do once tasker is set up (and its not difficult for just an alarm)
(with tools for the app 'tasker' its possible to send an signal to domoticz an certain time before your alarm goes off!
Posted: Saturday 07 May 2016 7:27
by Egregius
Or Google Calendar. Simple appointments like "Wake Alex", "Setpoint bathroom 21", "Switch kitchen On",...
Works great.
Posted: Saturday 07 May 2016 8:41
by jjnj
Actually, take a look at the app: morning routine. The apps lets you send a http get request when your alarm goes off in which you can set a domoticz switch
Verstuurd vanaf mijn LG-H850 met Tapatalk
Posted: Friday 13 May 2016 13:38
by Joerideman
I've considered the above options. I would still like it if I could use the domoticz app/online settings to set my alarm.
