Eurotronics Stella Z will not include
Posted: Thursday 05 May 2016 14:20
by hieronymus
I already have search on the internet for include my stella z thermostate unit to include in my z-wave network
I use a raspberry pi with zwave module on it.
I use the newest image off domoticz, no update required.
Fibaro relay en motion sensor i can add an control it but stella will not recognize.
Does somebody can help me to fix this problem
Also i have a problem with fibaro smoke sensor that it will not be active true the switches
Re: Eurotronics Stella Z will not include
Posted: Thursday 05 May 2016 15:37
by blackdog65
As an ex-stellaz user, I can say it is simple
1) exclude the stellaz
2) include the stellaz
3) exclude again as it didn't include properly
4) Keep repeating steps 1 to 3
Eventually it will include, it may sleep and never wake, it may eat batteries... I gave up on them in the end.
Posted: Thursday 05 May 2016 16:53
by hieronymus
Hmz okay this is was not what i hoping for.
What kind off thermostate do you use?
Posted: Thursday 05 May 2016 18:20
by jannl
Except for the batteries that remain only about 2 or 3 months, I never had any problem with the one stella z I use.
Posted: Thursday 05 May 2016 18:37
by hieronymus
batterij is no issue for me only that i can not include the stella z unit :s
Posted: Thursday 05 May 2016 19:03
by Westcott
Try putting Domoticz into Setup->Hardware->OpenZwave Setup button->Node management->Include node
Then hold the StellaZ button down for a moment until the steady green light shows.
See if the Include node dialogue shows the StellaZ.
If not, and still in Domoticz include mode, hold the button down for at least 15 seconds, ignoring any red or green lights.
That's how I got mine to include, the first time I tried.
Posted: Thursday 05 May 2016 23:44
by hieronymus
Both steps i have done without any include unit
Posted: Friday 06 May 2016 8:16
by jannl
Not sure if the accept new hardware setting in Domoticz must be set on.
Posted: Friday 06 May 2016 8:38
by gizmocuz
Try also to exclude first... maybe the module was tested
Also had a problem including this module, but it worked in the end.
First Domoticz in include mode, and then setting the stellaz in include mode
(Accept new hardware is done automatically)
Posted: Friday 06 May 2016 12:35
by blackdog65
As I said in my post and Gizmocuz too, EXCLUSION 1st is the most critical step. I do it by habit now with ALL z-wave products. All of which work very nicely for me with the exception of the StellaZ.
I now use the EQ3 Max! system for heating control (rads and stats) with a fibaro dual relay controlling heating and hot water. There is only limited support for EQ3 Max! in Domoticz but it works very well as a stand alone system.
Posted: Friday 06 May 2016 16:46
by hieronymus
If i use the exlusion function in domoticz, there's also nothing happening
If i exclude true vera edge it's say exclude device proberly but nothing happend on domoticz :S
Posted: Friday 06 May 2016 17:21
by blackdog65
Do you have other z-wave devices that work ok?
Posted: Friday 06 May 2016 17:52
by hieronymus
the follow unit are include in the network
fibaro relay switch 5x
fibaro motion sensor 3x
fibarp smoke sensor 3x
Posted: Sunday 22 May 2016 14:45
by hieronymus
I got 1 add to my system.
But i have 3 other stella witch i like to add.
But when i add them them same way i did with the first nothing is happening.
On stella the green led is on for 2 sec means it's enter zwave network.
With openremote i can exclude all device by hit 1 time on button.
1 i have include the same, but other seems not regornice
Posted: Sunday 22 May 2016 15:06
by Westcott
The green led for 2 secs just means that the StellaZ is awake.
See my post above.
Posted: Wednesday 28 December 2016 12:59
by hieronymus
Well finally i got include them but nothing will happen when I change the setting.
Look at the forum but find no sollution for this.
Any one has them work correctly?
Posted: Wednesday 28 December 2016 19:48
by jannl
I use 1 stellaz and it basically works without problems. I use a lua script to open and close the valve depending on the temperature. I included it from within Domoticz.
