FGMS001 Error
aleceuta
Domoticz version: 3.4834
FGMS001 Error
Post by aleceuta »
Recently add one Fibaro FGMS001 Multisensor to my Domoticz v3.4834, I have problems with Temperatureand Illumination report.
I try send new parameters but not working, the log on control panel:
2016-05-04 21:50:33.075 Error, Node033, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-05-04 21:50:33.076 Always,
2016-05-04 21:50:33.076 Always, Dumping queued log messages
2016-05-04 21:50:33.077 Always,
2016-05-04 21:50:33.077 Always, End of queued log message dump
2016-05-04 21:50:33.078 Always,
2016-05-04 21:50:43.088 Error, Node033, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-05-04 21:50:43.088 Always,
2016-05-04 21:50:43.088 Always, Dumping queued log messages
2016-05-04 21:50:43.089 Always,
2016-05-04 21:50:43.090 Always, End of queued log message dump
2016-05-04 21:50:43.097 Error, Node033, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2016-05-04 21:50:43.097 Always,
2016-05-04 21:50:43.097 Always, Dumping queued log messages
2016-05-04 21:50:43.098 Always,
2016-05-04 21:50:43.099 Always,
2016-05-04 21:50:43.099 Always, End of queued log message dump
2016-05-04 21:50:53.093 Error, Node033, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-05-04 21:50:53.093 Always,
2016-05-04 21:50:53.094 Always, Dumping queued log messages
2016-05-04 21:50:53.095 Always,
2016-05-04 21:50:53.095 Always, End of queued log message dump
2016-05-04 21:50:53.096 Always,
2016-05-04 21:50:53.103 Error, Node033, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2016-05-04 21:50:53.103 Always,
2016-05-04 21:50:53.104 Always, Dumping queued log messages
2016-05-04 21:50:53.105 Always,
2016-05-04 21:50:53.105 Always, End of queued log message dump
2016-05-04 21:51:03.098 Error, Node033, ERROR: Dropping command, expected response not received after 1 attempt(s)
2016-05-04 21:51:03.098 Always,
2016-05-04 21:51:03.099 Always, Dumping queued log messages
2016-05-04 21:51:03.100 Always,
2016-05-04 21:51:03.100 Always, End of queued log message dump
Is necesary include any line on xml file
Egregius
Domoticz version: v2024.7
Re: FGMS001 Error
Post by Egregius »
Do you wake the device to send the update?
aleceuta
Re: FGMS001 Error
Post by aleceuta »
Yes, now works, thanks.
