blockly, no event when using "and" combining motion and light status
Joerideman
Post by Joerideman »
I've started to experiment with MySensors and blockly. I only have one sensor and 1 actuator, both are childs of the same node.
I want to turn on the light only if the light was off and if there is motion. If the light is already on then there is no need to send another radio transmission.
The following example does not work.
I have tried a few other things that did work.
If motion sensor = on, Do Set light = on
If light = off, Do Set light = on
Both work. What am I doing wrong?
Extra info, I use Mysensors 1.5 and Domoticz Version: 3.4834
Shaggie_NB
Re: blockly, no event when using "and" combining motion and light status
Post by Shaggie_NB »
Look at your Blockly.....
You have to use the right logic blocks in the right place...
Joerideman
I swapped them. Is this okay?
Not so different to me.
Treve
Domoticz version: v4.11474
Post by Treve »
This must be working, Where D1 is a bulb. 2nd part you can see how it's build.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Joerideman
Guy I finally saw the difference :)
I start with the 'and' and then the inputs.
Thank you all.
@Treve I missed your comment, but that would have helped me.
Treve
Post by Treve »
Joerideman wrote:Guy I finally saw the difference :)
I tought "2nd part you can see how it's build." say's enough. you're fault was verry simple.
But it's working know, that's the goal.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
Joerideman
I meant that I read your reply (message and image) after I figured it out.
