Timer on/off doesn't work
Posted: Monday 02 May 2016 22:07
by thecosmicgate
Running the sonoff with v105 espeasy.
But when I use the default timer option it won't switch on or off .
When I use the icon to switch on / off everything is working fine :s
- uploadfromtaptalk1462219636560.png (195.51 KiB) Viewed 1585 times
Re: Timer on/off doesn't work
Posted: Friday 13 May 2016 10:15
by thecosmicgate
solved
Sent from my SM-G935F using Tapatalk
Posted: Friday 13 May 2016 10:16
by thecosmicgate
solved
Posted: Friday 13 May 2016 11:00
by SweetPants
Maybe nice for others if you post the solution also?
Posted: Saturday 14 May 2016 22:12
by thecosmicgate
Indeed nice , sorry
The solution was that simple: just wait a few minutes
seems that domoticz has something when you enter for example the on timer for 23:00 , entered on 22:59 doesn't work. The next day everything works perfectly and switched on at 23:00
