Avidsen doorbell (Hornbach)
Posted: Saturday 30 April 2016 11:28
by gdekeijzer
Does anybody know if the Avidsen doorbell will work on RFXCOM?
It uses the 433mhz channel.
Re: Avidsen doorbell (Hornbach)
Posted: Saturday 30 April 2016 12:55
by gdekeijzer
These are the codes and the device itself
Posted: Saturday 30 April 2016 13:22
by b_weijenberg
This device is not in the supported list, see chapter 2 of the RFXtrx User Guide.
However, you can try with RFXmngr and enable only Lighting4 or with an RFXtrx433E try also with only ByronSX enabled.
Posted: Wednesday 31 August 2016 12:46
by gdekeijzer
Ok, got some output in RFXmgr
chimed 2 times:
0913001500000000D580
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 21
Code = 000000
S1- S24 = 0000 0000 0000 0000 0000 0000
Pulse = 213 usec
Signal level = 8
0913001600000000D880
subtype = PT2262
Sequence nbr = 22
Code = 000000
Pulse = 216 usec
Signal level = 8
Now to create a lighting4 switch in Domoticz.
Posted: Wednesday 31 August 2016 13:24
by b_weijenberg
I suppose the message cannot be used because a RF packet with all zeroes is received.
Posted: Wednesday 31 August 2016 14:11
by gdekeijzer
My thoughts exactly. However, a PT2262 device was suddenly in my unused devices list, around 300 times... :|
(ok, havent been there awhile, but )
I'm moving on ..
