Domoticz does not show the Nefit Easy values
Posted: Saturday 30 April 2016 11:05
by menrone
I'm new on the Domoticz platform and started using the Nefit Easy module of Pepijn. I followed his instructions and everthing went well. In Node-RED is see the correct values passing by in the debugging window, something like:
{ "topic": "domoticz/in", "payload": { "idx": 77, "nvalue": 0, "svalue": "18" }, "_msgid": "427a478a.bd85b8" }
{ "topic": "domoticz/in", "payload": { "idx": 81, "nvalue": 0, "svalue": "6" }, "_msgid": "427a478a.bd85b8" }
{ "topic": "domoticz/in", "payload": { "idx": 79, "nvalue": 0, "svalue": "[ 0H ] Het cv-toestel staat stand-by." }, "_msgid": "266b0110.d994fe" }
But in Domoticz the objects wih the appropiate IDX (77, 79 and 81 in this case) don't show the values ie they are not updated. What part of the Node-RED objects isn't correctly set of what/where else did I wrong?
Thanks,
Wim
Re: Domoticz does not show the Nefit Easy values
Posted: Saturday 30 April 2016 14:08
by menrone
problem solved : MQTT was not well defined in Domoticz.
Wim
