How to use dimmer of Philio Tech Smart Color Button?
Posted: Friday 29 April 2016 8:28
by gvanrekum
I've got a Philio Tech Smart Color Button. I want this device to control my bathroom roller shutter. The switch is working (using node groups). I also want to use the dimmer function (to control the position of the roller shutter). But I can't get it working... :?
Any ideas?
Greetz,
Gerard
Re: How to use dimmer of Philio Tech Smart Color Button?
Posted: Tuesday 28 June 2016 13:11
by Cornholio1234
Hi Gerard,
I am thinking of buying one of these buttons - did you get it working?
Posted: Tuesday 28 June 2016 13:28
by gvanrekum
Yes I did, also using node groups. Only thing is that there is an delay of 8-10 seconds when controlling something with the switch.
Posted: Friday 01 July 2016 8:42
by Cornholio1234
Hi just got my new toy - but I cannot get any devices for it in domoticz. Can you only map it directly to a dimmer or did you manage to use it as a switch in domoticz?
I've got a nodon octan remote which will show me devices for each button and single, double, hold events...
Posted: Sunday 03 July 2016 19:54
by Cornholio1234
I got a little bit further... the control is working perfect with direct association to another node. But I cannot find a way of getting its values to domoticz.
I tried with Homegenie - the dim value shows up there without delay, so I assume it is something with the openzwave file. Only a little amount of the supported command classes are defined in the config. Is there anyone out there who might give me a tip what I can do to the config file to get my on/off /dim value? :-) I'd like to use it to control my receivers volume and I need the direct remote <-> controller connection ...
Posted: Thursday 07 July 2016 10:54
by Cornholio1234
Another update - but still not working: I played around with the config file after looking to the logs - log stated following, so I thought it may be something with the config:
2016-07-06 17:57:07.124 Info, Node035, Received Basic set from node 35: level=62. Treating it as a Basic report.
2016-07-06 17:57:07.125 Detail, Node035, Refreshed Value: old value=39, new value=62, type=byte
2016-07-06 17:57:07.125 Detail, Node035, Changes to this value are not verified
2016-07-06 17:57:07.125 Detail, Node035, Notification: ValueChanged
I am just trying around fully blind - after removing the "setasreport="true"" flag it changed from ValueChanged to NodeEvent
2016-07-06 18:53:23.746 Info, Node035, Received Basic set from node 35: level=42. Sending event notification.
2016-07-06 18:53:23.746 Detail, Node035, Notification: NodeEvent
but still no device in Domoticz. The wall switch is recognized like it should.
2016-07-06 18:53:24.182 Info, Node014, Received SwitchMultiLevel report: level=42
2016-07-06 18:53:24.182 Detail, Node014, Refreshed Value: old value=81, new value=42, type=byte
2016-07-06 18:53:24.182 Detail, Node014, Changes to this value are not verified
2016-07-06 18:53:24.182 Detail, Node014, Notification: ValueChanged
Anyone knowing how I can force domoticz to create me a device for node35 basic report?
Posted: Sunday 15 January 2017 19:18
by wile
did you suceed to include the buttons as devices?
I want to change the state of a virtual switch with the buttons (by script or scene or similar), however the button press does not reach the SW, so that I can react on it.
Posted: Thursday 09 March 2017 16:38
by micksel
Hi everyone. Any updates regarding this?
Also what is node groups, is there when you add another z-wave device id to the 2 group on the button?
