Changing Switch ID once set up
TheBod
Post by TheBod »
I am having some difficulty connecting some LightwaveRF On/Off sockets onto my Domoticz network. I think the problem is to do with the ID of the switches. When I try to Learn Light/Switch new On/Off sockets Domoticz says that it has already been used for the previous switch. I assume that if I can change the ID of the installed switch Domoticz would learn the new switch? Can devices ID's be changed once connected to Domoticz?
Are there any LightwaveRf gurus out there that can provide some assistance?
Thanks in advance
sijones
Domoticz version: Git
Re: Changing Switch ID once set up
Post by sijones »
Topic moved from wrong subforum.
You can associate any ID you want with the switches. You create your own switch and set the ID you want then click Test whilst using the devices learning method to make that switch learn the ID.
