Door sensor
Posted: Tuesday 19 April 2016 22:42
by ottoangel
I have bought this one: http://www.aliexpress.com/item/Free-shi ... 25731.html
Domoticz register it as an Chuango.
The problem is that nothing happens when I'm triggering it. I don't really now what switch type I should set it as.
I have made an blockly event so that it should turn on an outlet and turn on a lamp. According to the log things happen and under switches it turns on and so do the outlet but nothing happens in the real world. If I manually press the icon on the detector it turns on and the lamp also turns on but when triggering the sensor nothing happens. Maybe it works sometimes.
Any ideas?
Re: Door sensor
Posted: Wednesday 20 April 2016 0:23
by Stuntteam
It is a door contact. Normally you can set it as a contact.
However, it is important to check if the sensor sends 1 or 2 signals. With that I mean if it sends open and close as seperate signals or only sends an open signal.
Re: Door sensor
Posted: Wednesday 20 April 2016 8:06
by ottoangel
It seems to send just one signal so I have set 'off' with a 10 second delay.
Re: Door sensor
Posted: Thursday 21 April 2016 9:03
by ottoangel
If I restart Domoticz it seems to work for a while. It also seems that I got lots of double devices.
Maybe it isn't better than this?
Re: Door sensor
Posted: Thursday 21 April 2016 9:30
by Stuntteam
See pm.
