Ack when using MySensors with RFM69 radio
Posted: Tuesday 19 April 2016 19:36
Did some experiments with MySensors <-> Domoticz using the RFM69 radio module. I build a serial gateway and a simple relay node using the examples from MySensors. It all works fine, but one thing I noticed is when I power off the node the switch can still be operated in domoticz. It seems like Domoticz is not checking if the command is actually recieved by the node. Or maybe the node itself does not give an ack, I'm not sure.
I'm I missing something here, should I have set some otions or is this only working when using the NRF024 radio's ?
Now I do not have the real status of the node, only the last command that was send making it not any better then a simple one way device on the 433Mhz band.
Thanks !
Thanks !
