user access or property administration
Posted: Tuesday 19 April 2016 11:52
by thaui
Is there any property administartion planned for domoticz? I mean can an administrator handle the settings while a user (most of the people in a living place) can only use the rest of the system? This will also give the advantage to use the system in smaller offices.
Re: user access or property administration
Posted: Wednesday 20 April 2016 9:25
by Bikey
You already can create several users with different authorizations and access to pages. Isn't that sufficient?
Posted: Tuesday 26 April 2016 11:44
by thaui
Thanks for your reply. Will try it in the next few days and report if it fullfil my needs.
Posted: Wednesday 27 April 2016 16:13
by Skippiemanz
You can also grant users access to specific devices. So I think this could be used to achieve you're goal.
Verstuurd vanaf mijn SM-G925F met Tapatalk
Posted: Monday 02 May 2016 12:21
by Bikey
Skippiemanz wrote:You can also grant users access to specific devices. So I think this could be used to achieve you're goal.
How do you configure access to specific devices? I only see how to give access to specific pages.
Posted: Monday 02 May 2016 21:02
by Skippiemanz
Go to users, and in the same rol as active, name and rights you will find devices.
Verstuurd vanaf mijn HTC One_M8 met Tapatalk
Posted: Tuesday 03 May 2016 16:35
by Bikey
Skippiemanz wrote:Go to users, and in the same rol as active, name and rights you will find devices.
Yeah but that is to select if that user has rights to see the whole page of all devices. You can not select individual devices. I guess if you could allow this per room that would be a flexible solution.
Posted: Friday 14 April 2017 0:10
by lucalg
Good evening,
i'm interested too.
My need is to allow a list of users to come inside the parking. So I've created an event for a single user and works great.
Problem is that i have 250 tags to allow. So how to create a "you can park inside"list to work with event?
Tnx,
Luca
Posted: Thursday 11 May 2017 23:25
by EdddieN
Is this working?
I have created a new user and set devices/tabs to see but every time I try to log in it says incorrect username/password when logging from outside.
Maybe is my device that I have tampered quite a lot with lately....
Posted: Sunday 23 July 2017 14:19
by sincze
EdddieN wrote:Hello,
Is this working?
Did you find a solution?
I tried to add an extra user as viewer today and have the same issue.
Posted: Monday 24 July 2017 10:39
by EdddieN
No I didn't but when I tried on a fresh install on a 2nd Domoticz to connect to it remotely from another Domoticz it did work. So I assumed it was my 1st one that I had messed a fair bit with it.
Posted: Thursday 26 April 2018 22:41
by sincze
sincze wrote: Sunday 23 July 2017 14:19
Is this working?
Mmm I'm still having the same issue.
Wanted to add a user to allow controlicz a way in. However I'm unable to login with a newly created user..
2018-04-26 22:38:42.177 Error: Failed login attempt from xx.XXX.XXX.XX for user 'test' !
2018-04-26 22:39:08.931 Error: Failed login attempt from xx.XXX.XXX.XX for user 'test' !
1 have 1 user account (old old ancient) that is able to login... However all newly created accounts are not.
Posted: Thursday 26 April 2018 23:50
by EdddieN
I just tried to create a new one and log in externally with a Tor browser... same problem than before. Incorrect user/password. But I must mention that it is the same machine than before was giving me problems.
Have you tried on a different installation?
Posted: Friday 27 April 2018 11:38
by sincze
EdddieN wrote: Thursday 26 April 2018 23:50
This is a new installation on new HW, however, same old DB
Really strange
So 1 user that is already in the DB is working.
I created an additional one with username 'test' and pwd: 'test987' not working.... incorrect user/password.
If I open the DB with sql browser (ok username + pwd is hashed , excellent) the rest of the settings 'Active' , 'Rights', 'TabsEnabled" look the same. Beats me.
Posted: Friday 27 April 2018 17:59
by EdddieN
Ok, I just tried from outside my network and this way it works. I can create a new user from scratch or copy one and works fine.
Yesterday was trying from within my network, I wonder if it has to do with some conflict with the Settings page of asking for login for any IP not whitelisted?
Posted: Saturday 28 July 2018 18:55
by tudimon
Hello friends, can you help me?
I want to give limited access to my child in the domoticz - only two switches he can to switch.
I create user "artur" and gave him access to the tabs "switches" and "temperature" only. After that I give him access only several devices:
- Spoiler: show
- Screenshot_20180728-193428.png (129.7 KiB) Viewed 5605 times
- Screenshot_20180728-193505.png (125.36 KiB) Viewed 5605 times
When user Artur logged in domotics use Mobile Chrome it work correctly:
- Spoiler: show
- Screenshot_2018-07-28-14-27-51-551_com.android.chrome.png (201.02 KiB) Viewed 5605 times
He can view and can control only two switches.
But if he use app Domotics Lite, he can see and manage more - Events, User variables and Scenes.
How to limit access to user Artur in app Domotics Lite?
[offtop]Sorry for my bad english[/offtop]
Posted: Saturday 28 July 2018 19:42
by tudimon
Posted: Friday 12 July 2019 11:35
by hanskie
Any solution to solve this problem with domoticz lite ?
I have discovered yesterday the same issue.
