AOTEC GEN5 ZW074-C incomplet Device
Posted: Saturday 16 April 2016 18:49
by pascalde69
Hello, so here's my first post on this Domotics forum. All new to programming and the Raspberry but I'm already liking it.
My config Domoticz 3.5065 on Rasberry 2/Razberry & OZW 1.4-147-g23a6ff0
Afert insert my new multi sensor AOTEC GEN5 with "Include Node" (I try Include Node Secure too), only 5 devices appear in domoticz. Temp and Hum are absent. But all object are in Z-wave Control Panel.
Any idea ? Help is highly apreciated !
Log in domoticz durig the attachment :
2016-04-14 18:22:16.973 OpenZWave: New Node added. HomeID: 3943575454, NodeID: 44 (0x2c)
2016-04-14 18:22:17.124 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2016-04-14 18:22:17.125 (RazBerry) Light/Switch (Alarm Type)
2016-04-14 18:22:17.130 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2016-04-14 18:22:17.131 (RazBerry) Light/Switch (Alarm Level)
2016-04-14 18:22:17.136 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-04-14 18:22:17.136 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-04-14 18:22:17.136 (RazBerry) Light/Switch (Sensor)
2016-04-14 18:22:18.029 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-04-14 18:22:18.030 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2016-04-14 18:22:18.030 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
2016-04-14 18:22:18.143 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2016-04-14 18:22:18.143 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: ALARM, Label: Burglar, Instance: 1
2016-04-14 18:22:18.144 (RazBerry) Light/Switch (Burglar)
2016-04-14 18:22:29.362 OpenZWave: Received timeout notification from HomeID: 3943575454, NodeID: 44 (0x2c)
2016-04-14 18:22:38.200 (RazBerry) Usage (Unknown)
2016-04-14 18:22:38.202 (RazBerry) General/kWh (kWh Meter)
2016-04-14 18:22:56.325 (RazBerry) Usage (Unknown)
2016-04-14 18:22:56.327 (RazBerry) General/kWh (kWh Meter)
2016-04-14 18:22:59.843 OpenZWave: Received timeout notification from HomeID: 3943575454, NodeID: 44 (0x2c)
2016-04-14 18:23:02.185 (RazBerry) Temp + Humidity (TempHum)
2016-04-14 18:23:03.186 (RazBerry) Lux (Unknown)
2016-04-14 18:23:05.686 (RazBerry) Temp + Humidity (TempHum)
2016-04-14 18:23:44.160 (RazBerry) Usage (Unknown)
Re: AOTEC GEN5 ZW074-C incomplet Device
Posted: Monday 25 April 2016 13:21
by pascalde69
Post-resolved : the device is registred as
242 RazBerry 2E01 0 TMP HUM Allée Temp + Humidity WTGR800 26.0 C, 24 %
"0000" miss before the id number
Thks
Posted: Tuesday 26 April 2016 21:10
by hamish
Be nice if that inconsistency in id numbers could be fixed... I have raised a bug on github for it...
Posted: Tuesday 03 May 2016 23:46
by hamish
hamish wrote:Be nice if that inconsistency in id numbers could be fixed... I have raised a bug on github for it...
Ha ha... Apparently it's not a bug... BTFOM...
H
