My Z-Stick Gen5 will not work with USB HUB (Rpi)
Posted: Wednesday 13 April 2016 20:59
I'm not able to get my Z-stick to work with usb hub.
It's not being detected at all. (dmesg shows nothing) It works if I connect it directly to my Rpi.
My RFXCOM is working on the HUB.
Also my Current Cost (CP2102 USB to UART Bridge Controller) is being detected through the HUB.
Any suggestions?
Connected through HUB:
Connected directly:
Any suggestions?
pi@raspberrypi ~ $ sudo lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 010: ID 2001:f103 D-Link Corp. DUB-H7 7-port USB 2.0 hub
Bus 001 Device 012: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 001 Device 011: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) ICConnected directly:
Bus 001 Device 004: ID 0658:0200 Sigma Designs, Inc. <---- Z-Stick ????
Bus 001 Device 005: ID 2001:f103 D-Link Corp. DUB-H7 7-port USB 2.0 hub
Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 001 Device 007: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
pi@raspberrypi ~ $
pi@raspberrypi ~ $ sudo lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 2, If 0, Class=hub, Driver=hub/3p, 480M
|__ Port 1: Dev 3, If 0, Class=vend., Driver=smsc95xx, 480M
|__ Port 2: Dev 4, If 0, Class=comm., Driver=cdc_acm, 12M
|__ Port 2: Dev 4, If 1, Class=data, Driver=cdc_acm, 12M
|__ Port 3: Dev 5, If 0, Class=hub, Driver=hub/7p, 480M
|__ Port 1: Dev 6, If 0, Class=vend., Driver=cp210x, 12M
|__ Port 6: Dev 7, If 0, Class=vend., Driver=ftdi_sio, 12M
