reading out S0 kWh meter
Draakje
Domoticz version: 4.11539
Post by Draakje »
Hi All,
I need some help with understanding.
I have just installed a kWh meter with an S0 bus.
The manual of the kWh meter says that the 'pulse output rate is 2000 pulses per kWh(0,5Wh/imp)
I have bought the S0PCM (5 ports) to connect to the S0 bus.
I do see the meter in my Domoticz but the value it is displaying is incorrect.
Ex. I see on the display (SMA) that the current power is 40W and in domoticz I see around 200W.
Ex. I see in the total (week view) that I have around 27kW generated as in the 13,59kW which is displayed on the SMA
So this is kinda close to a double. Look to me like a setting.. ?
So maybe I need to do some fine tuning ?
I have no idea how.
Any idea's are welcome.
Regards,
Ronald
Hardware: Raspberry Pi 3, OTGW, 433MHz Superheterodyne 3310 RF Link
Software: Ubuntu 16.04, Domoticz v3.5468, WiringPi, rc-switch
gizmocuz
Re: reading out S0 kWh meter
Post by gizmocuz »
Okey, first you need to edit the s0 hardware and set it to 2000 pulses
Dont mind the first kwh total (first day), as it 'starts' somewhere during the day, but the next day total usage should be correct
Draakje
Post by Draakje »
Ok, I have set it to 2000 pulses.
Will see how this goes today..
thanks for the tip!
Draakje
Post by Draakje »
Thanks Gizmocuz,
That did the trick!
(Thread closed)
