RFXcom problem
ash1234
RFXcom problem
Post by ash1234 »
Hi All, I am new to the forum but have been running domoticz for a while using an RFXcom as my RF interface and a milight WIFI interface to control RGB fixtures. All this running on my windows home server which is on 24/7
I have ran into a problem the last few weeks.
When trying to turn on a light using the software it comes up with an error - Error sending switch command, check device/hardware !
this reports in the log saying RFXcom error opening serial port retrying in 30 seconds
BUT
When i press a scene button everything happens as it should. Also when i press a button on a siemens remote (which is linked to a scene to turn off an individual light) it works fine and reads correctly in the software.
So im at a bit of a loss as to what the problem is, everything seems to be as it should in device manager etc.
Any help will be greatly appreciated!
gizmocuz
Re: RFXcom problem
Post by gizmocuz »
Could it be you are using scripts or on/off actions ?
