V_WIND gives no device
Posted: Saturday 09 April 2016 9:35
by peerkersezuuker
I am building a solar power weather station :http://forum.mysensors.org/topic/841/so ... er-station
It works like a charm, for only 1 thing, the wind speed won't show up in domoticz as a device.
I use S_WIND/V_WIND and in the serial logs from the weather station i can see sending wind speed and in the mysensors serial gateway i see comming in wind speed.
In the hardware page in Domoticz i can see all the sensors of my weather station, including wind speed, but in the devices list all the sensors are present but not the wind speed (i blowto the wind speed sensor to generate some values, and i see them sending)
So why is the windspeed device not showing in my devices list ?
The Solar Weather station sketch:
    #include <SPI.h>
    #include <MySensor.h>
    #include <dht.h>
    #include <BH1750.h>
    #include <Wire.h>
    #include <Adafruit_BMP085.h>
    #include <MySigningAtsha204.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define CHILD_ID_BARO 3
    #define CHILD_ID_BTEMP 4
    #define CHILD_ID_WINDSPEED 5
    #define CHILD_ID_RAIN 6
    #define MESSAGEWAIT 500
    #define DIGITAL_INPUT_RAIN_SENSOR 3
    #define HUMIDITY_SENSOR_DIGITAL_PIN 5
    #define ENCODER_PIN 2
    #define INTERRUPT DIGITAL_INPUT_RAIN_SENSOR-2
    const int  windSpeedPin = 2; // contact on pin 2 digital
    int windSpeedPinCounter = 0; // impuls counter
    int windSpeedPinStatus = 0; // actual impuls
    int windSpeedPinStatusAlt = 0; // oude Impuls-Status
    unsigned long windmeterStart;
    unsigned long windmeterStartAlt = 0;
    int windSpeed; // Variable voor Wind Speed
    int beaufort = 0; // Variable Wind in Beaufort
    const int windmeterTime = 10000;
    //float knoten = 0.0;
    //float wind = 0.0;
    unsigned int knoten;
    unsigned int wind;
    boolean metric = false;
    int altitude = 16; // meters above sealevel
    float lastBmpTemp = -1;
    float lastPressure = -1;
    float lastHum = -1;
    float lastTemp = -1;
    double temp;
    double hum;
    int BATTERY_SENSE_PIN = A0;
    int lastRainValue = -1;
    int nRainVal;
    boolean bIsRaining = false;
    String strRaining = "NO";
    int lastBatteryPcnt = 0;
    int updateAll = 60;
    int updateCount = 0;
    uint16_t lastLux;
    // unsigned long SLEEP_TIME = 60000;
    unsigned long SLEEP_TIME = 600;
    int batteryBasement = 800;
    float batteryConstant = 100.0 / (1023 - batteryBasement);
    MyTransportNRF24 radio;  // NRFRF24L01 radio driver
    MyHwATMega328 hw; // Select AtMega328 hardware profile
    MySigningAtsha204 signer(true); // Select HW ATSHA signing backend
    Adafruit_BMP085 bmp = Adafruit_BMP085();
    BH1750 lightSensor;
    dht DHT;
    MySensor gw(radio, hw, signer);
    MyMessage msgHum(CHILD_ID_HUM, V_HUM);
    MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
    MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
    MyMessage msgBtemp(CHILD_ID_BTEMP, V_TEMP);
    MyMessage msgPressure(CHILD_ID_BARO, V_PRESSURE);
    MyMessage msgWindSpeed(CHILD_ID_WINDSPEED, V_WIND);
    MyMessage msgRain(CHILD_ID_RAIN, V_TRIPPED);
    void setup()
      analogReference(INTERNAL);
      gw.begin(incomingMessage, 3, true);
      //dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
      bmp.begin();
      gw.sendSketchInfo("Weather Sensor", "1.0");
      gw.present(CHILD_ID_HUM, S_HUM, "WS Humidity");
      gw.present(CHILD_ID_TEMP, S_TEMP, "WS Temperature");
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "WS Lux");
      gw.present(CHILD_ID_BARO, S_BARO, "WS Pressure");
      gw.present(CHILD_ID_BTEMP, S_TEMP, "WS P Temperature");
      gw.present(CHILD_ID_WINDSPEED, S_WIND, "WS Windspeed");
      gw.present(CHILD_ID_RAIN, S_MOTION, "WS Rain");
      pinMode(DIGITAL_INPUT_RAIN_SENSOR, INPUT);
      lightSensor.begin();
      metric = gw.getConfig().isMetric;
    // Wind Meter https://github.com/chiemseesurfer/arduinoWeatherstation/blob/master/weatherstation/weatherstation.ino
    float windmeter()
        windmeterStart = millis(); // Actual start time measuringMessung
        windmeterStartAlt = windmeterStart; // Save start time
        windSpeedPinCounter = 0; // Set pulse counter to 0
        windSpeedPinStatusAlt = HIGH; // Set puls status High
        while ((windmeterStart - windmeterStartAlt) <= windmeterTime) // until 10000 ms (10 Seconds) ..
            windSpeedPinStatus = digitalRead(windSpeedPin); // Read input pin 2
            if (windSpeedPinStatus != windSpeedPinStatusAlt) // When the pin status changed
                if (windSpeedPinStatus == HIGH) // When status - HIGH
                    windSpeedPinCounter++; // Counter + 1
            windSpeedPinStatusAlt = windSpeedPinStatus; // Save status for next loop
            windmeterStart = millis(); // Actual time
        windSpeed =  ((windSpeedPinCounter * 24) / 10) + 0.5; //  WindSpeed - one Pulse ~ 2,4 km/h,
        windSpeed = (windSpeed / (windmeterTime / 1000)); // Devided in measure time in seconds
        Serial.print("wind Speed : ");
        Serial.println(windSpeed);
        knoten = windSpeed / 1.852; //knot's
        return windSpeed;
    void loop()
      updateCount += 1;
      if (updateCount == updateAll) {
        lastTemp = -1;
        lastHum = -1;
        lastLux = -1;
        lastBmpTemp = -1;
        lastPressure = -1;
        lastRainValue = -1;
        lastBatteryPcnt = -1;
        updateCount = 0;
      delay(2000);
      int chk = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
      temp = DHT.temperature;
             //Serial.print("Temperature DHT :");
             //Serial.println(temp);
      if (isnan(temp)) {
          lastTemp = -1;
      } else if (temp != lastTemp) {
        lastTemp = temp;
        if (!metric) {
          temp = temp * 1.8 + 32.0;
        gw.send(msgTemp.set(temp, 1));
      hum = DHT.humidity;
      if (isnan(hum)) {
          lastHum = -1;
      } else if (hum != lastHum) {
          lastHum = hum;
          gw.send(msgHum.set(hum, 1));
      uint16_t lux = lightSensor.readLightLevel();
      if (lux != lastLux) {
          gw.send(msgLux.set(lux));
          lastLux = lux;
      float pressure = bmp.readSealevelPressure(altitude) * 0.01;
      float bmptemp = bmp.readTemperature();
      if (!metric) {
        bmptemp = bmptemp * 1.8 + 32.0;
      if (bmptemp != lastBmpTemp) {
        gw.send(msgBtemp.set(bmptemp,1));
        lastBmpTemp = bmptemp;
      if (pressure != lastPressure) {
        gw.send(msgPressure.set(pressure, 0));
        lastPressure = pressure;
      bIsRaining = !(digitalRead(DIGITAL_INPUT_RAIN_SENSOR));
             Serial.print("Is Raining :");
             Serial.println(bIsRaining);
      if(bIsRaining){
          strRaining = "YES";
      else{
          strRaining = "NO";
      //Serial.print("Raining?: ");
      //Serial.print(strRaining);
      //Serial.print("\t Moisture Level: ");
      //Serial.println(nRainVal);
      //http://henrysbench.capnfatz.com/henrys-bench/arduino-sensors-and-input/arduino-rain-sensor-module-guide-and-tutorial/
      gw.send(msgRain.set(bIsRaining, 1));
      wind = windmeter();
      Serial.print("Wind : ");
      Serial.println(wind);
      gw.send(msgWindSpeed.set(wind, 1));
      int sensorValue = analogRead(BATTERY_SENSE_PIN);
      int batteryPcnt = (sensorValue - batteryBasement) * batteryConstant;
      if (lastBatteryPcnt != batteryPcnt) {
        gw.sendBatteryLevel(batteryPcnt);
        lastBatteryPcnt = batteryPcnt;
      gw.sleep(SLEEP_TIME);
    void incomingMessage(const MyMessage & message) {
    // We only expect one type of message from controller. But we better check anyway.
     if (message.isAck()) {
       Serial.println("This is an ack from gateway");
The serial log of the Solar weather station (s5 is the windspeed value) :
wind Speed : 8
Wind : 8
send: 3-3-0-0 s=5,c=1,t=8,pt=7,l=5,sg=0,st=ok:8.0
send: 3-3-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:40.4
send: 3-3-0-0 s=2,c=1,t=23,pt=3,l=2,sg=0,st=ok:114
send: 3-3-0-0 s=4,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.9
send: 3-3-0-0 s=3,c=1,t=4,pt=7,l=5,sg=0,st=ok:1008
Is Raining :0
send: 3-3-0-0 s=6,c=1,t=16,pt=7,l=5,sg=0,st=ok:0.0
wind Speed : 7
Wind : 7
send: 3-3-0-0 s=5,c=1,t=8,pt=7,l=5,sg=0,st=ok:7.0
send: 3-3-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:41.1
send: 3-3-0-0 s=2,c=1,t=23,pt=3,l=2,sg=0,st=ok:84
send: 3-3-0-0 s=4,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.8
Is Raining :0
wind Speed : 1
Wind : 1
The serial log of the gateway :
0;0;3;0;9;read: 3-3-0 s=5,c=1,t=8,pt=7,l=5,sg=0:7.0
3;5;1;0;8;7.0
0;0;3;0;9;read: 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:41.1
3;0;1;0;1;41.1
0;0;3;0;9;read: 3-3-0 s=2,c=1,t=23,pt=3,l=2,sg=0:84
3;2;1;0;23;84
0;0;3;0;9;read: 3-3-0 s=4,c=1,t=0,pt=7,l=5,sg=0:21.8
3;4;1;0;0;21.8
0;0;3;0;9;read: 3-3-0 s=3,c=1,t=4,pt=7,l=5,sg=0:1008
3;3;1;0;4;1008
0;0;3;0;9;read: 3-3-0 s=6,c=1,t=16,pt=7,l=5,sg=0:0.0
3;6;1;0;16;0.0
The line with s=5 with the wind speed of 7
The hardware page in Domoticz :
Any help would be appriciated.
With regards
Peer
Re: V_WIND gives no device
Posted: Saturday 09 April 2016 13:37
by AWI
I built a similar device which shows up in Domoticz. Difference is that I also send V_DIRECTION from the same node. Domoticz is very creative in combining sensors (speed, direction & temp). I could well be that if there is no V_DIRECTION update the device is not shown/created.
You could try to send a dummy direction by sending a "0" with V_DIRECTION.
I managed to have the sensor created. (but have problems with the direction value which doesn't make sense).
If you need any examples, please tag me (@AWI) in the MySensors forum.
Posted: Sunday 10 April 2016 13:35
by peerkersezuuker
Hi AWI,
You're a life saver :D
That was the problem indeed.
Added gust and direction as dummy value's in the sketch and now it report's a device.
Thank you very much.
Regard's Peer
