ZMNHDD1 doesn't dim up
Posted: Friday 08 April 2016 21:52
by xces
I have a ZMNHDD1 which seems to be wired correctly as i can turn on and turn off the lights using the switch. Dimming down works, but dimming up doesn't, dimmer up using domoticz (setting the slider to e.g. 80%) also works
any tips?
Re: ZMNHDD1 doesn't dim up
Posted: Friday 08 April 2016 22:33
by Egregius
Parameter 20 is wrong. Now it's set to use two buttons.
Posted: Monday 11 April 2016 9:06
by xces
Are you sure, i have a 2 way pulse presser.
Pressing up should turn the light on, or when on to maximum (holding it should dim up)
Pressing down should turn the lights off, or dimming it should dim down
Posted: Monday 11 April 2016 16:09
by Egregius
You could try setting it to 'single push button' for test. It wasn't mentioned that there was a 2 way switch connected so I asumed a normal simple push button.
