Introducing mysel + question on home security
mgiammarco
Post by mgiammarco »
I would like to realize my "portable" security kit because I will be in a flat for several months for work in summer.
I plan to buy a Synology (with a big ups backup and a lte modem) and a thing like this:
http://www.ebay.it/itm/Fully-Solar-Wire ... SwbdpWVFEO
A wireless siren with wireless perimeter sensors with remotes.
I would like to use domoticz as a simple home security:
- enable/disable with remote (not with smartphone)
- in case of perimeter violation siren starts sounding and a sms or call is sent to my phone
- I will use also synology surveillance station to record videos with a simple cam
Can I use domoticz to:
- use 433 devices like above
- send sms or make voip calls to a list of numbers
- play siren
Is there a better way to do this type of things?
Thanks in advance,
Mario
mgiammarco
Re: Introducing mysel + question on home security
I see no replies probably I have expressed myself worng.
Basically I have found low cost solar siren and low cost solar perimeter infrared fencing sensors.
I would like to use them to implement a security system with domoticz.
But if you can suggest me better hardware for example z-wave compatible I am here to learn.
I would like to understand also how Domoticz can sens sms.
Thanks again,
Mario
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
Hi ,
How do you know that this product communicates in 433,92 Mhz ? I saw nothing in the product sheet about that. So I guess, there is no easy way it can interact with Domoticz.
Starting point for your need :
- wireless solution : search the forum for : chinese PIR motion sensor 433 and search for rfxTRX
- wired solution : search the web for : raspberry SR501 and look at that http://www.aliexpress.com/item/1pcs-Hig ... 22880.html
- search the domoticz.com/wiki and forum for : sms, notification.
for a wireless siren yes go to zwave
for a wired siren, search for raspberry gpio , or make sound with a raspberry. or look here : https://www.domoticz.com/wiki/Talking_Domoticz
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
