MutexImpl::Unlock error 0 (1)
Posted: Wednesday 06 April 2016 23:05
since severall days domoticz crashes on my Syno.
I'm running 3.5031, don't know for sure that the latest update caused this.
Because the logfile is cleared upon start of Domoticz I had to create a script to copy it to another location so I could look why the crash appears.
After each crash the logfile ends with this line:
I guess the only change I made was including a Fibaro Wall plug for some power measurement of a new device at home.
Another strange thing I notice is that each line that cames from Openzwave starts with strange brackets:
Last 10 minutes of the log:
For what I can find the Mutex is used so some things don't happen simultaneously, but then, what can cause the unlock error?
MutexImpl::Unlock error 0 (1)Another strange thing I notice is that each line that cames from Openzwave starts with strange brackets:
[39m[39m[39m[39m[39m[39m[39m[39m[39m[32m2016-04-05 11:27:24.908 Always,
2016-04-05 11:25:00.277 (ZWAVE) Usage (wasbakkookplaat2)
2016-04-05 11:25:00.278 (ZWAVE) General/kWh (Kwasbakkookplaat)
2016-04-05 11:25:02.802 (ZWAVE) General/kWh (Kwasbakkookplaat)
2016-04-05 11:25:02.866 (ZWAVE) Usage (wasbakkookplaat2)
2016-04-05 11:25:02.867 (ZWAVE) General/kWh (Kwasbakkookplaat)
2016-04-05 11:25:02.968 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:25:03.060 (ZWAVE) Usage (wasbak2)
2016-04-05 11:25:03.061 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:25:03.161 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:25:03.254 (ZWAVE) Usage (kookplaat2)
2016-04-05 11:25:03.264 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:25:06.310 (ZWAVE) Thermostat (kamerZ)
2016-04-05 11:25:09.471 (ZWAVE) Usage (garageterras)
2016-04-05 11:25:09.473 (ZWAVE) General/kWh (Kgarageterras)
2016-04-05 11:25:10.180 (ZWAVE) Thermostat (alexZ)
2016-04-05 11:25:20.983 (ZWAVE) Thermostat (livingZ)
2016-04-05 11:25:26.373 (RFXCOM) Lighting 2 (pirlivingR)
2016-04-05 11:25:26.940 Executing script: /volume1/web/secure/cron.sh
OPT =
2016-04-05 11:25:29.568 (ZWAVE) Usage (werkbladtuin2)
2016-04-05 11:25:29.569 (ZWAVE) General/kWh (Kwerkbladtuin)
2016-04-05 11:25:29.909 (ZWAVE) Light/Switch (pirliving)
2016-04-05 11:25:29.954 Executing script: /volume1/web/secure/cron.sh
OPT =
2016-04-05 11:25:33.844 (ZWAVE) Light/Switch (pirkeuken)
2016-04-05 11:25:33.967 Executing script: /volume1/web/secure/cron.sh
OPT =
2016-04-05 11:26:04.925 (ZWAVE) Usage (hallzolder)
2016-04-05 11:26:04.927 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:26:34.246 (ZWAVE) Light/Switch (pirkeuken)
2016-04-05 11:26:39.445 (ZWAVE) Thermostat (badkamerZ)
2016-04-05 11:27:02.495 User: Admin initiated a switch command
2016-04-05 11:27:02.495 (RFXCOM) Lighting 2 (pirlivingR)
2016-04-05 11:27:03.724 (ZWAVE) General/kWh (Kinkomvoordeur)
2016-04-05 11:27:03.788 (ZWAVE) Usage (inkomvoordeur2)
2016-04-05 11:27:03.789 (ZWAVE) General/kWh (Kinkomvoordeur)
2016-04-05 11:27:03.889 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:27:03.982 (ZWAVE) Usage (inkom2)
2016-04-05 11:27:03.983 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:27:04.083 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:27:04.175 (ZWAVE) Usage (voordeur2)
2016-04-05 11:27:04.176 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:27:04.815 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:27:04.905 (ZWAVE) Usage (alex Power Meter)
2016-04-05 11:27:04.907 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:27:13.201 (ZWAVE) Light/Switch (pirkeuken)
2016-04-05 11:27:13.354 (ZWAVE) Light/Switch (pirgarage)
2016-04-05 11:27:14.087 Executing script: /volume1/web/secure/cron.sh
OPT =
[31m2016-04-05 11:27:14.905 Error, Node089, ERROR: Dropping command, expected response not received after 1 attempt(s)
[39m[32m2016-04-05 11:27:14.905 Always,
[39m[32m2016-04-05 11:27:14.905 Always, Dumping queued log messages
[39m[39m[39m[39m[39m[39m[39m[39m[39m[32m2016-04-05 11:27:14.905 Always,
[39m[32m2016-04-05 11:27:14.906 Always, End of queued log message dump
[39m2016-04-05 11:27:14.906 OpenZWave: Received timeout notification from HomeID: 25487143, NodeID: 89 (0x59)
2016-04-05 11:27:16.101 Executing script: /volume1/web/secure/cron.sh
OPT =
[31m2016-04-05 11:27:24.908 Error, Node089, ERROR: Dropping command, expected response not received after 1 attempt(s)
[39m[32m2016-04-05 11:27:24.908 Always, Dumping queued log messages
[39m[32m2016-04-05 11:27:24.909 Always, End of queued log message dump
[39m2016-04-05 11:27:24.909 OpenZWave: Received timeout notification from HomeID: 25487143, NodeID: 89 (0x59)
2016-04-05 11:27:40.679 (ZWAVE) Thermostat (livingZZ)
2016-04-05 11:27:41.674 (ZWAVE) Thermostat (livingZE)
2016-04-05 11:28:03.280 (ZWAVE) Thermostat (kamerZ)
2016-04-05 11:28:05.205 (ZWAVE) Thermostat (alexZ)
2016-04-05 11:28:05.579 (ZWAVE) Temp (alex)
2016-04-05 11:28:10.080 (ZWAVE) Light/Switch (pirliving)
2016-04-05 11:28:14.081 (ZWAVE) Light/Switch (pirkeuken)
2016-04-05 11:28:17.083 (ZWAVE) Thermostat (livingZ)
2016-04-05 11:28:18.438 (RFXCOM) Lighting 2 (pirlivingR)
2016-04-05 11:28:31.964 (ZWAVE) Light/Switch (pirgarage)
2016-04-05 11:28:33.261 (RFXCOM) Lighting 2 (poort)
2016-04-05 11:28:33.805 (RFXCOM) Lighting 2 (poort)
2016-04-05 11:28:34.194 Executing script: /volume1/web/secure/cron.sh
OPT =
2016-04-05 11:28:36.207 Executing script: /volume1/web/secure/cron.sh
OPT =
2016-04-05 11:28:36.346 (ZWAVE) Light/Switch (pirgarage)
2016-04-05 11:28:39.219 Executing script: /volume1/web/secure/cron.sh
OPT =
2016-04-05 11:28:44.991 (ZWAVE) Usage (lichtbadkamerB)
2016-04-05 11:28:44.992 (ZWAVE) General/kWh (Klichtbadkamer)
2016-04-05 11:29:03.600 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:29:03.719 (ZWAVE) Usage (hallzolder)
2016-04-05 11:29:03.720 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:29:03.874 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:29:04.022 (ZWAVE) Usage (hall)
2016-04-05 11:29:04.024 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:29:04.179 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:29:04.327 (ZWAVE) Usage (zolder)
2016-04-05 11:29:04.338 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:29:06.269 Sending SetPoint to device....
2016-04-05 11:29:28.963 (ZWAVE) Usage (inkomvoordeur2)
2016-04-05 11:29:28.964 (ZWAVE) General/kWh (Kinkomvoordeur)
2016-04-05 11:29:33.458 (ZWAVE) Thermostat (badkamerZ)
2016-04-05 11:29:37.108 (ZWAVE) Light/Switch (pirgarage)
2016-04-05 11:29:48.444 (ZWAVE) Light/Switch (pirgarage)
2016-04-05 11:29:49.309 Executing script: /volume1/web/secure/cron.sh
OPT =
2016-04-05 11:29:53.134 (ZWAVE) Temp (badkamer)
2016-04-05 11:29:57.976 (ZWAVE) Usage (keukenzolderg2)
2016-04-05 11:29:57.977 (ZWAVE) General/kWh (Kkeukenzolderg)
2016-04-05 11:29:58.627 (RFXCOM) Lighting 2 (poort)
2016-04-05 11:30:01.930 (ZWAVE) Usage (wasbakkookplaat2)
2016-04-05 11:30:01.931 (ZWAVE) General/kWh (Kwasbakkookplaat)
2016-04-05 11:30:02.934 (ZWAVE) General/kWh (Kkeukenzolderg)
2016-04-05 11:30:02.998 (ZWAVE) Usage (keukenzolderg2)
2016-04-05 11:30:02.999 (ZWAVE) General/kWh (Kkeukenzolderg)
2016-04-05 11:30:03.099 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:30:03.192 (ZWAVE) Usage (keuken2)
2016-04-05 11:30:03.193 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:30:03.292 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:30:03.385 (ZWAVE) Usage (zolderg2)
2016-04-05 11:30:03.386 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:30:03.855 (ZWAVE) General/kWh (Kwerkbladtuin)
2016-04-05 11:30:03.919 (ZWAVE) Usage (werkbladtuin2)
2016-04-05 11:30:03.921 (ZWAVE) General/kWh (Kwerkbladtuin)
2016-04-05 11:30:04.021 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:30:04.113 (ZWAVE) Usage (werkblad2)
2016-04-05 11:30:04.114 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:30:04.214 (ZWAVE) General/kWh (Ktuin)
2016-04-05 11:30:04.307 (ZWAVE) Usage (tuin2)
2016-04-05 11:30:04.319 (ZWAVE) General/kWh (Ktuin)
2016-04-05 11:30:10.984 (ZWAVE) Usage (garageterras)
2016-04-05 11:30:10.985 (ZWAVE) General/kWh (Kgarageterras)
2016-04-05 11:30:30.410 (ZWAVE) Usage (werkbladtuin2)
2016-04-05 11:30:30.412 (ZWAVE) General/kWh (Kwerkbladtuin)
2016-04-05 11:30:37.900 (ZWAVE) Thermostat (livingZZ)
2016-04-05 11:30:38.785 (ZWAVE) Thermostat (livingZE)
2016-04-05 11:30:49.257 (ZWAVE) Light/Switch (pirgarage)
2016-04-05 11:31:00.233 (ZWAVE) Thermostat (alexZ)
2016-04-05 11:31:00.283 (ZWAVE) Thermostat (kamerZ)
2016-04-05 11:31:00.572 (ZWAVE) Thermostat (alexZ)
2016-04-05 11:31:03.111 (ZWAVE) General/kWh (Klichtbadkamer)
2016-04-05 11:31:03.174 (ZWAVE) Usage (lichtbadkamerB)
2016-04-05 11:31:03.176 (ZWAVE) General/kWh (Klichtbadkamer)
2016-04-05 11:31:03.276 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:31:03.368 (ZWAVE) Usage (lichtbadkamer1B)
2016-04-05 11:31:03.369 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:31:03.469 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:31:03.561 (ZWAVE) Usage (lichtbadkamer2B)
2016-04-05 11:31:03.563 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:31:04.029 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:31:04.197 (ZWAVE) Usage (zoldertrap2)
2016-04-05 11:31:04.208 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:31:06.489 (ZWAVE) Usage (hallzolder)
2016-04-05 11:31:06.490 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:31:13.187 (ZWAVE) Thermostat (livingZ)
2016-04-05 11:32:03.357 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:32:03.421 (ZWAVE) Usage (zithoek)
2016-04-05 11:32:03.431 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:32:27.497 (ZWAVE) Thermostat (badkamerZ)
2016-04-05 11:33:02.982 (ZWAVE) General/kWh (Kmedia_unused)
2016-04-05 11:33:03.016 (ZWAVE) Usage (media_unused)
2016-04-05 11:33:03.017 (ZWAVE) General/kWh (Kmedia_unused)
2016-04-05 11:33:03.052 (ZWAVE) General/kWh (Ktv)
2016-04-05 11:33:03.088 (ZWAVE) Usage (tv2)
2016-04-05 11:33:03.090 (ZWAVE) General/kWh (Ktv)
2016-04-05 11:33:03.124 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.161 (ZWAVE) Usage (kristal2)
2016-04-05 11:33:03.162 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.197 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.239 (ZWAVE) Usage (tvled2)
2016-04-05 11:33:03.240 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.275 (ZWAVE) General/kWh (Ksubwoofer)
2016-04-05 11:33:03.311 (ZWAVE) Usage (subwoofer2)
2016-04-05 11:33:03.312 (ZWAVE) General/kWh (Ksubwoofer)
2016-04-05 11:33:03.347 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.383 (ZWAVE) Usage (kodi2)
2016-04-05 11:33:03.384 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.419 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.455 (ZWAVE) Usage (bureel)
2016-04-05 11:33:03.456 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.931 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:03.995 (ZWAVE) Usage (tobi2)
2016-04-05 11:33:03.997 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:33:04.448 (ZWAVE) General/Thermostat Mode (brander)
2016-04-05 11:33:35.120 (ZWAVE) Thermostat (livingZZ)
2016-04-05 11:33:35.997 (ZWAVE) Thermostat (livingZE)
2016-04-05 11:33:45.741 (ZWAVE) Usage (lichtbadkamerB)
2016-04-05 11:33:45.743 (ZWAVE) General/kWh (Klichtbadkamer)
2016-04-05 11:33:55.249 (ZWAVE) Thermostat (alexZ)
2016-04-05 11:33:57.272 (ZWAVE) Thermostat (kamerZ)
2016-04-05 11:34:09.454 (ZWAVE) Thermostat (livingZ)
2016-04-05 11:34:30.060 (ZWAVE) Usage (inkomvoordeur2)
2016-04-05 11:34:30.061 (ZWAVE) General/kWh (Kinkomvoordeur)
2016-04-05 11:34:59.358 (ZWAVE) Usage (keukenzolderg2)
2016-04-05 11:34:59.359 (ZWAVE) General/kWh (Kkeukenzolderg)
2016-04-05 11:35:03.212 (ZWAVE) General/kWh (Kgarageterras)
2016-04-05 11:35:03.275 (ZWAVE) Usage (garageterras)
2016-04-05 11:35:03.276 (ZWAVE) General/kWh (Kgarageterras)
2016-04-05 11:35:03.377 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:35:03.469 (ZWAVE) Usage (garage2)
2016-04-05 11:35:03.470 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:35:03.570 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:35:03.609 (ZWAVE) Usage (wasbakkookplaat2)
2016-04-05 11:35:03.611 (ZWAVE) General/kWh (Kwasbakkookplaat)
2016-04-05 11:35:03.663 (ZWAVE) Usage (terras2)
2016-04-05 11:35:03.673 (ZWAVE) General/kWh (kWh Meter)
2016-04-05 11:35:12.667 (ZWAVE) Usage (garageterras)
2016-04-05 11:35:12.668 (ZWAVE) General/kWh (Kgarageterras)
2016-04-05 11:35:21.488 (ZWAVE) Thermostat (badkamerZ)
2016-04-05 11:35:30.875 (ZWAVE) Usage (werkbladtuin2)
2016-04-05 11:35:30.876 (ZWAVE) General/kWh (Kwerkbladtuin)
