Using a phonecall to set a switch
Posted: Wednesday 06 April 2016 9:32
by martk
I have a electrical port to my house, which I have connected to domoticz using a relay switch.
I want to be able to open the port when someone calls a phonenumber, for example using a prepaid sim card in a certain device which I can connect to domoticz.
Anyone ever did this? What is the easiest way?
Unfortunately I don't have a Fritzbox but a Ziggo modem. so this is not an option.
Re: Using a phonecall to set a switch
Posted: Wednesday 06 April 2016 10:21
by dakipro
Hi, I was planning to do something similar with a tasker and a old dedicated android phone.
Then it is just to make a simple profile in tasker that will trigger the Json url of domoticz to change some switch, or script or whatever.
Should be relatively easy, just a bit learning of tasker if you never used it
Posted: Wednesday 06 April 2016 12:20
by martk
Ok, that is an option indeed, I do need an old phone then. Any other options?
