Page 1 of 2
RFLink and Synology problems/challenges
Posted: Wednesday 06 April 2016 1:02
by To0wnn
I tried anything what was said on the forms the scratch the RESET-EN, 10uF capasitor and the command killall synousbmodemd.
But none of those things makes the RFLink work with my synology it recieves commands but it not transmitting.
2016-04-06 00:48:59.419 RFLink Sending: 10;NewKaku;c2d5a2;2;OFF
2016-04-06 00:49:04.000 Error: RFLink: TX time out.
Any suggestions?
Re: RFLink and Synology problems/challenges
Posted: Wednesday 06 April 2016 1:32
by jumbotroll
To0wnn wrote:Hi,
Any suggestions?
Need some more info!
What NAS do you have and what DSM version?
Domoticz version?
RLink version?
What Revision Arduino Mega R1, R2 or R3?
You may also be able to disable the auto-reset by connecting a 110 ohm resistor from 5V to the reset line.
It can also be some problem with older kernel drivers on some older NAS.
Posted: Wednesday 06 April 2016 19:57
by To0wnn
jumbotroll wrote:To0wnn wrote:Hi,
Any suggestions?
Domoticz version?
RLink version?
What NAS do you have and what DSM version?-- DS412+ and DSM 6.0-7321
Domoticz version?-- 3.5031
RLink version?-- v1.1_r39
What Revision Arduino Mega R1, R2 or R3?-- R3
Posted: Wednesday 06 April 2016 20:34
by jumbotroll
I have done some testing on my DS-712+ with DSM 6.0.
Arduino Mega 2560 R3
RESET-EN Jumper is NOT removed!
Synousbmodemd is NOT killed!
For some strange reason this works excellent on DSM 6.0
Did not work without modification on DSM 5.2
2016-04-06 20:12:27.002 Domoticz V3.5040 (c)2012-2016 GizMoCuz
2016-04-06 20:12:27.002 Build Hash: d4e41bd-modified, Date: 2016-04-06 00:40:10
2016-04-06 20:12:29.483 RFLink: Using serial port: /dev/ttyACM1
2016-04-06 20:12:30.404 RFLink: Controller Initialized!...
2016-04-06 20:12:30.480 RFLink Detected, Version: 1.1 Revision: 39 Build: 1
2016-04-06 20:25:18.712 RFLink Sending: 10;NewKaku;299c3f2;10;ON
2016-04-06 20:25:22.636 User: Admin initiated a switch command
2016-04-06 20:25:22.636 RFLink Sending: 10;NewKaku;299c3f2;10;OFF
2016-04-06 20:32:35.849 (RFlink) Temp (Temp bathroom)
2016-04-06 20:33:00.435 (RFlink) Temp + Humidity (Klima Server)
Posted: Wednesday 06 April 2016 22:08
by To0wnn
I tried the 110 ohm resistor but no luck with it.
The strange thing that when i connect the arduino die L led is burning full power and is slowing dimming and then stays on in dimmed state..
Posted: Wednesday 06 April 2016 22:14
by jumbotroll
To0wnn wrote:I tried the 110 ohm resistor but no luck with it.
Maybe some USB power problem?
The LED is not dimming here.
Try a external power supply.
And if you have USB Hub, try to connect without USB Hub.
Posted: Thursday 07 April 2016 0:19
by To0wnn
Looks like a gnd or driver problem but everything looks ok..
Also when i connect it to my laptop everything is working correctly in one time.
Tried the external power also not working..
No hub is used..
Posted: Friday 08 April 2016 18:58
by marcojpolet
Perhaps your cable is bad ?
Verstuurd vanaf mijn SM-G920F met Tapatalk
Posted: Tuesday 05 July 2016 8:42
by To0wnn
Treid a different cable.. still issues with the RFLink
Someone any new suggestions?
2016-07-05 08:35:15.191 RFLink Sending: 10;NewKaku;c2d5a2;2;OFF
2016-07-05 08:35:20.000 Error: RFLink: TX time out...
Posted: Wednesday 06 July 2016 8:03
by deennoo
@To0wnn
Update your rflink (r42 is here) and get domoticz last beta it will work
Posted: Wednesday 06 July 2016 8:04
by To0wnn
Already done.. no luck..
Posted: Thursday 21 July 2016 13:45
by L2v2P
To0wnn wrote:Already done.. no luck..
I experience the same problems every now and then after updating Domoticz. Usually upgrading the firmware of the RFLink does the trick. However, just now I got things to work again by first disabling and then again enabling the RFLink via Setup | Hardware in Domoticz. Might work for you as well.
Posted: Saturday 23 July 2016 14:59
by Afvoer
Did any of you got it work yet?
Tried:
- RFLink and arduino work perfectly on my Microsoft drone (W7 laptop)
- updated RFLink R42
- connecting GND - RESET with capacitator
From time to time I get TX errors in Domoticz log.
Posted: Sunday 24 July 2016 0:56
by Stuntteam
Does your Arduino have a CH340 or Atmel chip for the usb/serial port?
Posted: Thursday 28 July 2016 9:51
by bendora
Dear users
I ve compiled RFLink software on arduino mega clone with NES. I linked de reset and the ground with a capasitor 10 uF.
Ik had worked for a day and then it stops with receiving. I ve to reboot the synology again.
I m using Domoticz version 3,5338 with R42.
Posted: Thursday 28 July 2016 11:32
by Stuntteam
Are you using the jadahl synology package?
Can be found here:
http://www.jadahl.com/
Posted: Thursday 28 July 2016 11:39
by bendora
Yes beta version
Posted: Tuesday 16 August 2016 8:28
by To0wnn
I got some sequence that it is working now when you reconnect the rf link you must give the command trough ssh killall synousbmodemd.
Then go to Domoticz "Setup>Hardware" select the rflink device deselect "Enable" click on "Update".
Select rflink device again select "Enable" again and click on "Update"
This is what worked for me. I did not make any hardware modifications.
I don't know how to permanently disable the synousbmodemd.
Any suggestions?
Posted: Wednesday 08 February 2017 10:39
by veteiks
i have issues with rflink, i have Synology ds216play with domoticz package from jadahl for dsm 6.0 (Domoticz for Synology Stable V3.5877 for DSM 6.0), on synology is dsm 6.0.2. On RFlink is version R45 and connect via USB to synology usb 2.0 (i tried 3.0 too). RFlink (arduino) is with 10uF capacitator in reset-gnd, RFlink is from nodo shop (synology package)
I added on synology hardware RFlink gataway usb, with port /dev/ttyUSB0 ..
in log is only .. RFLink: Using serial port: /dev/ttyUSB0
but not message .. RFLink: Controller Initialized!... and RFLink Detected, Version: xxxxx
Please, any suggestions?? thank you
Posted: Wednesday 08 February 2017 11:22
by Stuntteam
Do you have an Arduino with CH340 or Atmega serial chip?
The Ch340 does not need the anti reset modification..
