Luxaflex PowerView and Domoticz?
Posted: Monday 04 April 2016 9:47
by Awst6000
I saw on the Luxaflex-website that there is something new: Luxaflex PowerView.
Can this be used with Domoticz/RFXcom?
Op de site staat vermeld:
Het PowerView™ Motorisation systeem is compatibel met de tablets en mobiele apparaten van Apple® iOS en Android™ om de mogelijkheden van een draadloos huis uit te breiden. Het is eveneens compatibel met de meeste domoticatechnologieën die vandaag de dag op de markt zijn.
Txs
Re: Luxaflex PowerView and Domoticz?
Posted: Tuesday 05 April 2016 15:26
by Awst6000
I found the following info:
http://www.hunterdouglas.com/operating- ... ional-info
It seems that PowerView has it's own hub and can be combined with the Harmony Hub.
Posted: Sunday 22 May 2016 13:43
by Awst6000
Still nobody bought this?
Txs
Posted: Saturday 18 June 2016 18:04
by TheSpanishInq
They have a serial api. It's not exactly cheap, about €340,- extra for a motorized top/down screen and then you'll still need a remote and a hub. (serial works with hub). They use a proprietary protocol over 2.4Ghz for the old remotes. Could well be they use this for the new product too. Not sure if it interferes with your WiFi connection...
Bid to steep for our budget. :|
Posted: Sunday 12 March 2017 10:13
by Marcel
The PowerView hub can be talked to through ip example: https://github.com/bradfitz/powerview/b ... werview.go
this is also described in their pages
With the addition of the PowerView Hub, window coverings with PowerView Motorization can be integrated into a home automation system via RS-232 serial input or IP (internet protocol) from many common systems.
Now the wait is for someone to implement! I will buy this set this year anyhow because I really like it!
Posted: Saturday 10 November 2018 16:15
by rasper
Anyone any luck with building/integrating powerview with Domoticz?
Posted: Friday 31 January 2020 13:10
by nitpicker
Posted: Friday 31 January 2020 16:15
by FireWizard
With this description https://github.com/drbrain/indigo-power ... w%20API.md
and some programming (script or node-red) it should be possible to connect to Domoticz.
Posted: Monday 17 May 2021 9:49
by Timothy
is anyone interested in developing a plugin for Luxaflex?
Posted: Tuesday 25 May 2021 12:00
by Cropper17
I just stumbled upon your blog and wanted to say that I have really enjoyed reading your blog posts.
