Philio PAT02-B 2 in 1 Multi Sensor
andersbz
Post by andersbz »
Hello
Is there a plan to include this sensor (Philio PAT02-B 2 in 1 Multi Sensor ) in Domoticz? I have succed to include it into my network and I can receive temprature and humidity (wrong value) but it's not possible to configurate. I think this depends on that there is no xml file for this sensor in ~/domoticz/Config/philio.
Anders (beginner)
andersbz
Re: Philio PAT02-B 2 in 1 Multi Sensor
Post by andersbz »
Thanks to someone. Now there is a xml file for this sensor.
Regards Anders
sharif
Domoticz version: 3.5574
Post by sharif »
Where exactly is the xml for this file? I can not find it and configuration of the sensor is minimal
My PAT02-B (2 in 1 temp + humidity) are shown like this in the Domo (tested from stable version to current 3.5574)
Philio Technology Corporation Unknown: type=0002, id=0020
And only settings on the sensor is Wake Up interval, nothing else.
I do get the values of temp and humidity, but I would love to be able to actually configure the sensors as well.
Contents of my /usr/local/domoticz/Config/philio folder
pan03.xml pan08.xml phpsg01.xml psm02.xml pst02-1c.xml pst02.xml
pan04.xml phpat02.xml pse02.xml psr04.xml pst02-b.xml
sharif
Post by sharif »
Ok so
This file shows pat02-b
cd /usr/local/domoticz/Config ; grep -i pat02-b manufacturer_specific.xm
<Product type="0002" id="0020" name="PH-PAT02-B.eu Multisensor 2in1" config="philio/phpat02.xml"/>
then
cat phpat02.xml
At the beginning that file states its for 3in1 sensor....which pat02-b is not.
<!-- Philio Technology Corporation PH-PAT02 Multisensor 3in1 sold as Zipato brend -->
None of the possible settings defined in that XML file are showing up on my pat02-b sensors
Any tips?
sharif
Post by sharif »
Nevermind, deleted the zwcfg file and now suddenly they are dropping in correctly as "Philio Technology Corporation PH-PAT02-B.eu Multisensor 2in1"
