Cresta UV meter scale not right within RFLink
Posted: Saturday 02 April 2016 12:08
I have a Cresta UV meter http://weerstationteraar.nl/content/gra ... %20uv2.PNG which is recognized within RFLink as a UVN128,UV138.
It's working, I get a new value every 5 minutes but the scale is wrong. The value I get is for example 7.0 which should be 0.7. Is's a factor 10 wrong.
The same sensor is recognized under Rfxcom as a TFA and there I get 0.7 and also the temperature value which is also inside this UV sensor.
Here a dump of this sensor:
Hopefully it can be fixed, thanks in advance
20;3A;Cresta;ID=9601;TEMP=8d1b;UV=0015;BAT=LOW;
20;3B;DEBUG;Pulses=132;Pulses(uSec)=930,930,840,930,840,450,330,450,330,930,360,420,840,930,330,420,840,930,360,420,840,930,330,450,330,420,840,930,840,420,360,420,360,930,840,930,360,420,840,930,840,930,330,450,840,450,330,930,360,420,360,450,330,450,840,420,330,930,840,420,360,930,840,420,360,420,330,450,330,450,330,450,330,930,840,930,840,420,330,930,360,450,840,420,360,930,360,450,330,450,840,930,330,450,330,450,840,930,840,930,360,420,360,420,330,420,840,420,330,450,360,420,360,930,360,450,360,420,330,450,330,420,330,450,840,930,330,450,840,930,330,420;
