IDX instead of switchnames in LUA?
Bikey
- Domoticz version: 2020.x
I thought I've read this earlier in the forum, but can't find it, so forgive me if this have been answered before:
My problem is:
In LUA the actual names of devices have to be used for for commands, like commandArray['MySwitchName'] = 'Off'
Problem is, if you change the name of your device, this will break all LUA-scripts.
So question is: is there a way to use the IDX-value instead of the names in your LUA-scripts? This is also how BLockly works.
My problem is:
Bikey
Re: IDX instead of switchnames in LUA?
This would think this is a common "problem", has anybody found a solution to make your scripts resilient against changing device names?
tozzke
- Domoticz version: Stable
not really that I know of.... except for creating local variables at the top of your script and use them instead of the full switch names. In this way you'll only have to change that the name of the switch once at each script
mrf68
I like the fact that I can use the names instead of the IDX. One of my contacts didn't work properly anymore. I had a spare, placed it at the door, used the name of the old one (after renaming the old one first) and started to use it. I don't need to go through all the scripts, it just works. So I wouldn't vote for IDX instead of names, I could live with IDX AND names.
Bikey
Yeah, that is how I do this now as well. Would even be better if you could have 1 place to maintain al those assignments for all scripts. I'm just starting with LUA, but I imagine that you could use something like an include file?tozzke wrote:not really that I know of.... except for creating local variables at the top of your script and use them instead of the full switch names. In this way you'll only have to change that the name of the switch once at each script
jmleglise
- Domoticz version: 2022.1
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
KMTronic USB relay
- jvdz
- Domoticz version: 4.107
Something like this should also work using the new otherdevices_idx[] table in LUA to get the current devicename for an IDX.
untested code example:
Jos
function getdevname4idx(deviceIDX)
for i, v in pairs(otherdevices_idx) do
if v == deviceIDX then
return i
return 0
commandArray[getdevname4idx(123)] = 'Off'
supermat
jvdz wrote:Something like this should also work using the new otherdevices_idx[] table in LUA to get the current devicename for an IDX.
untested code example:JosCode: Select all
function getdevname4idx(deviceIDX) for i, v in pairs(otherdevices_idx) do if v == deviceIDX then return i end end return 0 end commandArray[getdevname4idx(123)] = 'Off'
Thank you JVDZ this is what I am searching.
SjoerdNLD
I was also searching for this; Now using name for my scripts, instead of IDX.
You can just use: otherdevices_idx["Bathroom Light"]
Source: http://www.domoticz.com/forum/viewtopic.php?t=12010
I build the latest armv6 here https://github.com/SjoerdNLD/Domoticz-Armv6/releases
