Raspberry 3 + zwave +domoticz
Posted: Sunday 27 March 2016 21:32
by Kerneldomoticz
Hello all,
i'm really new in the linux world so i hope i will be able to find some help here
i'm trying to install the raspberry image from the SD cardon a PI3 with a GPIO zwave module :
the thing is it appears that PI3 and new bluetooth and wifi module is causing issues ... as per this topic :
http://forum.z-wave.me/viewtopic.php?f=3422&t=22957
let me know if my logic is good in what i want :
- download domoticz SD card + isntall it on micro sd card
- do the basic setup
-install openzwave if not already in the image
- setup the zwave GPIO module to work as an USB device using this tutorial:
http://www.vesternet.com/resources/appl ... veekdDl-2k
- go in domoticz and set the zwave as openzwave usb
but i don't think it works ...did someone got the PI3 + my zwave module up and running ?
do i have to install the Zwave server ?
also my zwave module is in firmware 2.2.1
please let me know what i should do to have everything working.
thx by advance.
Re: Raspberry 3 + zwave +domoticz
Posted: Sunday 27 March 2016 22:28
by nukie
Cant help you all the way..but.
You are mixing things up.
First you talk about Domoticz and then you seems to be on Zwave server 2.2.1 (Z-wave.me), you do not need z-wave server. 2.2.1 is not the firmware version on the module its the version of the server software. Firmware should be 5.0 to 5.0.4. Check this thread:
http://forum.z-wave.me/viewtopic.php?f=3422&t=22361
If you want to use Domoticz you have to forget about z.wave.me. If you want to update the firmware you have to use Z.wave server as far as i know- but it a bit tricky and some fail while upgrading.
Set up domoticz as the wiki suggests:
https://www.domoticz.com/wiki/Domoticz_ ... i_SD_Image
On rpi3 you probably want to do "rpi-update" to upgrade the rpi firmware.
Posted: Sunday 27 March 2016 23:01
by Kerneldomoticz
Hello Nukie,
yes i might be mixing things ... i did some ditro test the last 2 days
1- raspian + zway server + domoticz
2 - raspian + domticz + openzwave
now - domticz sd card and waiting for help
you are saying i can't use and i have to forget my zwave GPIO module to use domoticz ? i saw a a bunch of install with domoticz and the zwave module i bought. so do you mean i can sell the module i bought and buy a usb stick instead ?
I followed the wiki page for install but not much to do from SD card
right now i'm doing the RPI update.
Posted: Monday 28 March 2016 9:52
by nukie
No, your z-wave modul will work fine once you set ít up. Im using RPi2 (with the same modul as you) so i cant help you with RPi3. You should use the "jessie" image - but i guess you are if you followed the wiki. I have domoticz running without problems on my RPi3 - but without additional hardware.
Look at this thread - it might help:
viewtopic.php?f=24&t=10964
ps. What i ment with "forget" was the software "z-wave server" from Z-wave.me. ds
Posted: Monday 28 March 2016 11:43
by Kerneldomoticz
hey,
Thx for the reply
i know domoticz run fine on the pi3 but the major difference between the pi3 and the pi2 is the bluetooth and wifi integration .... which break the zwave module and it can't run like this ..
i will check your link and i will also go on the zwave forum as they are working on a workaround.
Flo
Posted: Monday 28 March 2016 12:19
by Kerneldomoticz
ok it seems that now i'm ok
kernel update was the missing part.
just waiting for my first zwave device to arrive to run the test. but so far in the logs no errors !
thx for the help ! much appreciated !
flo
