Setting up motion detection with Foscam FI9900P
Posted: Sunday 27 March 2016 17:17
I am currently trying to setup motion detection by using my Foscam FI9900P.
So far i have successfully added the cam to Domoticz, i have a (virtual) switch and i understand (tested) how to turn that specific switch on/off.
I have to say, i'm new to Linux, Raspberry Pi and just starting with Domoticz. Being familiar with PHP, i do understand a bit of coding and i already have some LUA scripts running... Linux itself is still a bit of a mystery to me!
I have installed the "motion package" and i think i have got it running pretty much. The hardest part now seems to be the configuring, especially with Foscam since i learned that it doesn't support a raw mjpeg stream. However, the snapshot URL seems to work fine and within Domoticz i am able to open the camera stream. To me it seems that Domoticz also doesn't bother with raw mjpeg, but uses snapshots instead.
Anyway, after some day's i am now about to give up... so maybe someone here to help me out or give some direction. My logfile seems to say there is an issue with rights... but i don't need to save anything, i only want to trigger motion right now. Next step could be to save some pictures and send out an email with those attached.
Here's my logfile:
Here's my logfile:
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] conf_load: Processing thread 0 - config file /etc/motion/motion.conf
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] motion_startup: Using default log level (NTC) (6)
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] motion_startup: Motion 3.2.12+git20140228 Started
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] motion_startup: Logging to syslog
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] motion_startup: Using default log type (ALL)
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] motion_startup: Using log type (ALL) log level (NTC)
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ENC] ffmpeg_init: ffmpeg LIBAVCODEC_BUILD 3670016 LIBAVFORMAT_BUILD 3670272
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] main: Thread 1 is from /etc/motion/motion.conf
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] main: Thread 1 is device: http://192.168.#.##:##/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USERNAME&pwd=PASSWORD input -1
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] main: Stream port 0
Mar 27 16:49:24 raspberrypi motion: [0] [NTC] [ALL] main: Waiting for threads to finish, pid: 10701
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [ALL] motion_init: Thread 1 started , motion detection Enabled
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [NET] netcam_read_first_header: Non-streaming camera (keep-alive not set)
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [NET] netcam_read_first_header: Content-length present
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [NET] netcam_read_first_header: Found Conn: close header ('Connection: close')
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [NET] netcam_setup_html: connected, going on to read image.
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [NET] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [NET] netcam_read_html_jpeg: leaving netcam connected.
Mar 27 16:49:24 raspberrypi motion: [1] [NTC] [ALL] image_ring_resize: Resizing pre_capture buffer to 1 items
Mar 27 16:49:29 raspberrypi motion: [1] [NTC] [NET] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
Mar 27 16:49:29 raspberrypi motion: [1] [NTC] [NET] netcam_read_html_jpeg: leaving netcam connected.
Mar 27 16:49:30 raspberrypi motion: [1] [NTC] [NET] netcam_read_first_header: Non-streaming camera (keep-alive not set)
Mar 27 16:49:30 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Sun Mar 27 16:51:00 2016 [try http://www.rsyslog.com/e/2007 ]
Mar 27 16:49:30 raspberrypi motion: [1] [NTC] [NET] netcam_read_first_header: Content-length present
Mar 27 16:49:30 raspberrypi motion: [1] [NTC] [NET] netcam_read_first_header: Found Conn: close header ('Connection: close')
Mar 27 16:49:30 raspberrypi motion: [1] [NTC] [NET] netcam_read_html_jpeg: disconnecting netcam since keep-alive not set.
Mar 27 16:49:30 raspberrypi motion: [1] [NTC] [NET] netcam_read_html_jpeg: leaving netcam connected.
Mar 27 16:49:30 raspberrypi motion: [1] [NTC] [ALL] motion_loop: Thread exiting
Mar 27 16:49:30 raspberrypi motion: [0] [NTC] [ALL] main: Threads finished
Mar 27 16:49:31 raspberrypi motion: [0] [NTC] [ALL] main: Motion terminating
Mar 27 16:51:00 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Sun Mar 27 16:52:30 2016 [try http://www.rsyslog.com/e/2007 ]
Mar 27 16:53:00 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Sun Mar 27 16:54:30 2016 [try http://www.rsyslog.com/e/2007 ]
Mar 27 16:55:00 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Sun Mar 27 16:56:30 2016 [try http://www.rsyslog.com/e/2007 ]
Mar 27 16:57:00 raspberrypi rsyslogd-2007: action 'action 17' suspended, next retry is Sun Mar 27 16:58:30 2016 [try http://www.rsyslog.com/e/2007 ]
