Not getting KAKU switch to work with RFLink on Synology
gggr
Post by gggr »
This week I bought a RFLink transceiver and some KAKU switches to play around with. I am running Domoticz on my Synology DS115 (package from Jumbotroll, currently version 3.5010). The RFLink is recognized immediately, however I cannot add any KAKU switches no matter how I try. I keep getting timeouts when I send a command to the switch.
To make sure that everything is working I attached the RFLink to my Windows PC and installed Domoticz on that PC. Added the RFLink and the KAKU switches were recognized first try! So the problem must be somewhere in my Synology setup.
Below is the log of one of my tries. As you can see the RFLink is sending a command but then it just waits for the timeout, while the switch is in learning mode. I even tried to add the switch on my Windows PC and then (without resetting the switch) add it to my Synology with the same ID, but that did not work as well. So my guess is something goes wrong sending the command from the Synology?
I am not sure what I can do next to investigate or collect more information to solve this problem, so if anyone has pointers on that please shoot. Thanks in advance.
2016-03-26 21:32:42.803  Domoticz V3.5010 (c)2012-2016 GizMoCuz
2016-03-26 21:32:42.804  Build Hash: ba3c523-modified, Date: 2016-03-24 19:13:29
2016-03-26 21:32:42.804  Startup Path: /usr/local/domoticz/
2016-03-26 21:32:43.403  Active notification subsystems: http (1/11)
2016-03-26 21:32:44.164  WebServer(HTTP) started on address: :: with port 8084
2016-03-26 21:32:44.200  WebServer(SSL) started on address: :: with port 8443
2016-03-26 21:32:44.244  Proxymanager started.
2016-03-26 21:32:44.252  Starting shared server on: :::6144
2016-03-26 21:32:44.272  TCPServer: shared server started...
2016-03-26 21:32:44.277  RxQueue: queue worker started...
2016-03-26 21:32:46.316  EventSystem: reset all events...
2016-03-26 21:32:46.318  EventSystem: reset all device statuses...
2016-03-26 21:32:46.346  EventSystem: Started
2016-03-26 21:32:46.559  RFLink: Using serial port: /dev/ttyACM0
2016-03-26 21:32:47.476  RFLink: Controller Initialized!...
2016-03-26 21:32:47.569  RFLink Detected, Version: 1.1 Revision: 39 Build: 1
2016-03-26 21:35:40.568  Incoming connection from: 192.168.0.118
2016-03-26 21:36:50.549  RFLink Sending: 10;NewKaku;3333233;3;ON
2016-03-26 21:36:55.006  Error: RFLink: TX time out...
2016-03-26 21:36:55.518  RFLink Sending: 10;NewKaku;3333233;3;ON
2016-03-26 21:37:00.022  Error: RFLink: TX time out...
2016-03-26 21:37:32.188  RFLink Sending: 10;NewKaku;3333233;3;ON
2016-03-26 21:37:37.000  Error: RFLink: TX time out...
2016-03-26 21:37:37.372  RFLink Sending: 10;NewKaku;3333233;3;ON
2016-03-26 21:37:42.007  Error: RFLink: TX time out...
Voyager
Re: Not getting KAKU switch to work with RFLink on Synology
Post by Voyager »
From the FAQ:
Synology NAS:
Q: What do I need to use RFlink on a Synology NAS?
A: If you want to use RFLink with a Synology NAS you can use:
- an Arduino Mega clone based on CH340 USB/serial chip
In all other cases:
- connect a 10 uF capacitor between reset and ground on the Arduino.
Simply stick the pins of the capacitor in the power connector socket.
When you want to update the firmware of the Arduino, remove the capacitor and reconnect it when done.
For details about the Domoticz Synology package check out: http://www.jadahl.com
Did you add the 10uf capacitor?
gggr
Post by gggr »
I use this set: http://www.nodo-shop.nl/nl/rflink-gatew ... enne-.html, which contains an Arduino Mega clone that I believe has the CH340 chip (I am not at home right now so I cannot check but the website list the drivers: http://www.nodo-shop.nl/nl/arduino/10-a ... tible.html).
So then I do not need the capacitor?
gggr
Post by gggr »
Problem solved!
I was reading other threads from people having problems with their Synology and that got me examing system logs on my Synology (/var/log/messages). There I found a the following lines that kept on repeating themselves indefinitely.
Mar 29 21:20:04 synousbmodemd: usbmodem_lib/usbmodem_devicenodehandler.cpp:278 No respond on modem cmd AT+CPIN?
Mar 29 21:20:04 synousbmodemd: usbmodem_lib/usbmodem_simhandler.cpp:50 Warning: sim mute before handler init
Mar 29 21:20:04 synousbmodemd: usbmodem_lib/usbmodem.cpp:481 failed on setup sim handler
Mar 29 21:20:04 synousbmodemd: usbmodem_lib/usbmodem_list.cpp:116 Failed to init info [2004]
Mar 29 21:20:04 synousbmodemd: usbmodem_lib/usbmodem.cpp:709 USBModem [2004] is not inited
After some more googling I found this post: viewtopic.php?f=17&t=2620&start=660#p77572. I executed the command from that post and now everything is working fine.
So it seems that the RFLink gateway was not properly recognized by the Synology, although it did show up in Domoticz.
