LightwaveRF contact switch
Posted: Wednesday 23 March 2016 23:17
by Truff
I have a lightwaveRF contact switch which is recognised by RFLink and Domoticz, and in the Domoticz log I can see it creating an identical log entry for opening and closing.
But in the actual log for the switch this is just showing as status OFF for the opening/closing events so the contact switch never appears to be triggered. In order for something to visibly occur when the contact opens would I need to write some sort of script ?
Re: LightwaveRF contact switch
Posted: Wednesday 23 March 2016 23:54
by simonrg
Truff wrote:But in the actual log for the switch this is just showing as status OFF for the opening/closing events so the contact switch never appears to be triggered. In order for something to visibly occur when the contact opens would I need to write some sort of script ?
I thought these sent both off and on signal. Which LightwaveRF part number is it?
Even if a switch is already off, and it sends another off, it will trigger an event as devicechanged in Lua or the off action will occur. You should see this is the text log for the switch, but the graph will a flat line.
Posted: Thursday 24 March 2016 0:27
by Stuntteam
It sounds like an issue we just fixed.. check your PM.
Posted: Thursday 24 March 2016 19:30
by Truff
Just a quick note to say the LightwaveRF contact switch is now working great after assistance from Stuntteam and now its correctly logging the opening and closing of the contacts.
I've also got 5 LightwaveRF Dimmer switches working around the house now using RFLink so its all looking very good indeed.
Posted: Wednesday 27 April 2016 1:27
by ivanzaster
Please could you send the solution
I got the same problem with the Lightwaverf sensor.
It works perfect and sent notifications but suddenly only sent off signals
Thanks in advance
Posted: Sunday 29 October 2017 13:37
by SHadley1138
i wonder if you could tell me how you paired the lightwaverf contact switch, as its driving me nuts.....
thanks in advance
Pi, RFLink
