Remeha advanta\calenta Central Heating
Posted: Wednesday 23 March 2016 13:26
by Fabnik1s
Is ther a Way to add my Remeha avanta 35C through serial.
I already have a Serial Port Working with the Remeha
but how do i add this in domotics ?
see link below For the serial details.
http://blog.hekkers.net/2010/10/03/moni ... a-calenta/
gr Fabian
Re: Remeha advanta\calenta Central Heating
Posted: Monday 27 June 2016 16:08
by Fabnik1s
so nobody can tell me how to add the serial connection ?
Posted: Monday 27 June 2016 17:08
by Mediacj
Nice information, you could make a php script to put it into Domoticz. See the Domoticz wiki for json options. Also look at this page: https://www.domoticz.com/wiki/Extractin ... s_with_PHP
But this interface is only monitoring? There is no way to change the setpoint?
Posted: Friday 04 November 2016 22:20
by mickeyr61
I made a cable (like this one found here http://blog.hekkers.net/2011/03/14/reme ... revisited/ ). I think the cable is working OK, but I cannot get any data from the Remeha Calenta 40W. I have used the official Remeha program and the OTMonitor program. Any tips?
Posted: Saturday 05 November 2016 9:22
by stlaha2007
As far i can read, the cable is ment to be used by the software Remeha Recom. Which has the ability to export the info to file.
What your trying to do is interfacing improperly.
You need to write/build your interface-program yourself.
OTGW is hardware, like this cable.
OTGW is nativly supported by Domoticz with programlogic which translates info from/to OTGW to/from Domoticz.
Sent from my D6603 using Tapatalk
Posted: Wednesday 14 December 2016 14:33
by rjblake
mickeyr61 wrote:I made a cable (like this one found here http://blog.hekkers.net/2011/03/14/reme ... revisited/ ). I think the cable is working OK, but I cannot get any data from the Remeha Calenta 40W. I have used the official Remeha program and the OTMonitor program. Any tips?
@mickeyr61, I connected an FTDI cable (simple Adafruit FTDI Friend) to my Calenta 40C and managed to get Recom to recognise and work just fine (can read and write to Calenta). I have also connected an ESP8266 directly to the Calenta RS232 port and can send/receive data using RealTerm (don't use Putty or other as cannot send/receive HEX). When you say 'I think the cable is working', what makes you think that? Have you managed to get Recom working? If not, I'd say your cable is not working (perhaps RX & TX are swapped). If Recom is connecting and and receiving data, then you can move on to the next step. If you want to send/receive info over the serial, you'll need a terminal emulator that sends/received HEX. RealTerm (windows) is tried and tested and known to work. In addition, you'll need to send a command to the Calenta to get a response. It does not send a constant stream of data, but a single response each time you send the command. I understand this varies by model and revision (for my Calenta it is 0x02 0xFE 0x01 0x05 0x08 0x02 0x01 0x69 0xAB 0x03)
OTMonitor is specific to the Opentherm Gateway has no relevance in the RS232 connection from PC to Calenta.
