RFLink with Nodo Slave - kwh meter not counting anymore?
marcojpolet
Post by marcojpolet »
I have a strange issue I'm stuck with. I have a kwh counter in a Nodo Slave, it worked fine. I had a few issues with eratic (extremely high) kwh measures, so, I deleted the device in Domoticz, and currently I want it back! But it doesn't show up anymore...
My config: Domiticz 3.4834 (Jumbotroll package), RFLink V39. I use a Nodo slave (744), with a small meter script. This used to work before, and it is currently also sending to the RFLink, this is the output:
20;3E;PONG;
20;3F;Slave;ID=000301;METER=00000046;
20;40;PONG;
20;41;Slave;;
20;42;PONG;
The problem is; in the Domoticz log I see it entering:
2016-03-20 20:10:48.246 (RFLink) RFXMeter (Slave)
So the output RFLink is talking to Domoticz and the Slave is talking to the RFLink, but, the device is not showing up in the devices list.
Please give me some hints on how to get the device back.
Regards,
Marco
marcojpolet
Re: RFLink with Nodo Slave - kwh meter not counting anymore?
No ideas at all guys? Could it have to do with my recent upgrade to V39 of the RFLink?
Regards,
Marco
Stuntteam
Post by Stuntteam »
It does not look like an issue with rflink.
As you mention the slave device is detected and the counter values are forwarded to Domoticz.
Also the log shows: 2016-03-20 20:10:48.246 (RFLink) RFXMeter (Slave)
meaning that the device is recognized already within Domoticz..
marcojpolet
Hmm don't know what happened (various reboots of Domotiz/NAS probably), but the counter is back! So that's the good news. Too bad; I have my original problem back, see this picture:
There is an extermely high counter value. The others seem zero, but are actually more in the rang of 8kWh, 10kWh, etc., so that seems appropriate. Any idea what might cause this? Should I add something in my Nodo Small script not to upload a counter if it is in the range of Megawatts? Or isn't this caused there?
Regards,
Marco
Stuntteam
Post by Stuntteam »
You could just log with rflink loader (regular log, no debug log) to see if there are any extreme values coming from the Nodo small.
Then we can determine what the best point is to fix this.
marcojpolet
Captured the output of the RFLink of last night (roughly). It looks pretty good. In the log of earlier I also did a capture, but I had this running using minicom AND Domoticz-enabled. I also have a reset-timer of 5 minutes. So, I disabled the RFLink in Domoticz, then ran minicom with capture and got this output:
20;46;Slave;ID=000301;METER=00000025;
20;47;Slave;ID=000301;METER=00000036;
20;48;Slave;ID=000301;METER=0000002d;
20;49;Slave;ID=000301;METER=00000032;
20;4A;Slave;ID=000301;METER=00000053;
20;4B;Slave;ID=000301;METER=0000004a;
20;4C;Slave;ID=000301;METER=0000006b;
20;4D;Slave;ID=000301;METER=00000020;
20;4E;Slave;ID=000301;METER=0000002c;
20;4F;Slave;ID=000301;METER=0000001a;
20;50;Slave;ID=000301;METER=00000019;
20;51;Slave;ID=000301;METER=0000002a;
20;52;Slave;ID=000301;METER=00000046;
20;53;Slave;ID=000301;METER=0000001d;
20;54;Slave;ID=000301;METER=0000002d;
20;55;Slave;ID=000301;METER=00000048;
20;56;Slave;ID=000301;METER=00000019;
20;57;Slave;ID=000301;METER=0000003f;
20;58;Slave;ID=000301;METER=00000029;
20;59;Slave;ID=000301;METER=00000017;
20;5A;Slave;ID=000301;METER=00000012;
20;5B;Slave;ID=000301;METER=00000042;
20;5C;Slave;ID=000301;METER=00000013;
20;5D;Slave;ID=000301;METER=0000004f;
20;5E;Slave;ID=000301;METER=00000035;
20;5F;Slave;ID=000301;METER=00000038;
20;60;Slave;ID=000301;METER=0000004d;
20;61;Slave;ID=000301;METER=00000035;
20;62;Slave;ID=000301;METER=0000001e;
20;63;Slave;ID=000301;METER=00000021;
20;64;Slave;ID=000301;METER=00000013;
20;65;Slave;ID=000301;METER=0000002e;
20;66;Slave;ID=000301;METER=00000032;
20;67;Slave;ID=000301;METER=0000003e;
20;68;Slave;ID=000301;METER=0000002c;
20;69;Slave;ID=000301;METER=00000023;
20;6A;Slave;ID=000301;METER=00000036;
20;6B;Slave;ID=000301;METER=00000030;
20;6C;Slave;ID=000301;METER=00000030;
20;6D;Slave;ID=000301;METER=00000037;
20;6E;Slave;ID=000301;METER=00000049;
20;6F;Slave;ID=000301;METER=0000000d;
20;70;Slave;ID=000301;METER=00000050;
20;71;Slave;ID=000301;METER=00000030;
20;72;Slave;ID=000301;METER=00000035;
20;73;Slave;ID=000301;METER=0000001c;
20;74;Slave;ID=000301;METER=0000000f;
20;75;Slave;ID=000301;METER=00000010;
20;76;Slave;ID=000301;METER=0000001b;
20;77;Slave;ID=000301;METER=00000050;
20;78;Slave;ID=000301;METER=00000042;
20;79;Slave;ID=000301;METER=00000026;
20;7A;Slave;ID=000301;METER=00000053;
20;7B;Slave;ID=000301;METER=00000034;
20;7C;Slave;ID=000301;METER=00000049;
20;7D;Slave;ID=000301;METER=00000041;
20;7E;Slave;ID=000301;METER=00000039;
20;7F;Slave;ID=000301;METER=00000042;
20;80;Slave;ID=000301;METER=00000020;
20;81;Slave;ID=000301;METER=00000021;
20;82;Slave;ID=000301;METER=0000000b;
20;83;Slave;ID=000301;METER=00000026;
20;84;Slave;ID=000301;METER=00000084;
20;85;Slave;ID=000301;METER=00000023;
20;86;Slave;ID=000301;METER=000000dc;
20;87;Slave;ID=000301;METER=00000022;
20;88;Slave;ID=000301;METER=00000046;
20;89;Slave;ID=000301;METER=0000000c;
20;8A;Slave;ID=000301;METER=00000075;
20;8B;Slave;ID=000301;METER=000000ac;
20;8C;Slave;ID=000301;METER=00000050;
20;8D;Slave;ID=000301;METER=00000016;
20;8E;Slave;ID=000301;METER=00000018;
20;8F;Slave;ID=000301;METER=00000012;
20;90;Slave;ID=000301;METER=0000002a;
20;91;Slave;ID=000301;METER=0000000e;
20;92;Slave;ID=000301;METER=0000006c;
20;93;Slave;ID=000301;METER=00000033;
20;94;Slave;ID=000301;METER=00000045;
20;95;Slave;ID=000301;METER=00000018;
20;96;Slave;ID=000301;METER=0000003f;
20;97;Slave;ID=000301;METER=00000045;
20;98;Slave;ID=000301;METER=0000002c;
20;99;Slave;ID=000301;METER=0000001c;
20;9A;Slave;ID=000301;METER=00000002;
20;9B;Slave;ID=000301;METER=00000056;
20;9C;Slave;ID=000301;METER=00000000;
20;9D;Slave;ID=000301;METER=0000006b;
20;9E;Slave;ID=000301;METER=00000000;
20;9F;Slave;ID=000301;METER=00000097;
20;A0;Slave;ID=000301;METER=00000000;
20;A1;Slave;ID=000301;METER=00000064;
20;A2;Slave;ID=000301;METER=0000005f;
20;A3;Slave;ID=000301;METER=00000000;
20;A4;Slave;ID=000301;METER=00000066;
20;A5;Slave;ID=000301;METER=00000000;
20;A6;Slave;ID=000301;METER=00000072;
20;A7;Slave;ID=000301;METER=00000000;
20;A8;Slave;ID=000301;METER=0000005d;
20;A9;Slave;ID=000301;METER=0000004f;
20;AA;Slave;ID=000301;METER=00000000;
20;AB;Slave;ID=000301;METER=00000069;
20;AC;Slave;ID=000301;METER=00000000;
20;AD;Slave;ID=000301;METER=0000007c;
20;AE;Slave;ID=000301;METER=00000046;
20;AF;Slave;ID=000301;METER=00000000;
20;B0;Slave;ID=000301;METER=00000051;
20;B1;Slave;ID=000301;METER=00000039;
20;B2;Slave;ID=000301;METER=00000000;
20;B3;Slave;ID=000301;METER=0000004d;
20;B4;Slave;ID=000301;METER=00000017;
20;B5;Slave;ID=000301;METER=0000001d;
20;B6;Slave;ID=000301;METER=0000004a;
20;B7;Slave;ID=000301;METER=00000040;
20;B8;Slave;ID=000301;METER=0000002a;
20;B9;Slave;ID=000301;METER=00000046;
20;BA;Slave;ID=000301;METER=00000000;
20;BB;Slave;ID=000301;METER=00000010;
20;BC;Slave;ID=000301;METER=0000003c;
20;BD;Slave;ID=000301;METER=00000033;
20;BE;Slave;ID=000301;METER=00000047;
20;BF;Slave;ID=000301;METER=0000001b;
20;C0;Slave;ID=000301;METER=00000000;
20;C1;Slave;ID=000301;METER=0000003d;
20;C2;Slave;ID=000301;METER=00000038;
20;C3;Slave;ID=000301;METER=00000045;
20;C4;Slave;ID=000301;METER=00000000;
20;C5;Slave;ID=000301;METER=00000064;
20;C6;Slave;ID=000301;METER=00000000;
20;C7;Slave;ID=000301;METER=0000005e;
20;C8;Slave;ID=000301;METER=00000000;
20;C9;Slave;ID=000301;METER=00000062;
20;CA;Slave;ID=000301;METER=00000000;
20;CB;Slave;ID=000301;METER=0000005a;
20;CC;Slave;ID=000301;METER=00000021;
20;CD;Slave;ID=000301;METER=00000039;
20;CE;Slave;ID=000301;METER=00000040;
20;CF;Slave;ID=000301;METER=00000000;
20;D0;Slave;ID=000301;METER=0000005d;
20;D1;Slave;ID=000301;METER=00000000;
20;D2;Slave;ID=000301;METER=00000091;
20;D3;Slave;ID=000301;METER=00000000;
20;D4;Slave;ID=000301;METER=00000069;
20;D5;Slave;ID=000301;METER=0000004c;
20;D6;Slave;ID=000301;METER=00000000;
20;D7;Slave;ID=000301;METER=0000006e;
20;D8;Slave;ID=000301;METER=00000000;
20;D9;Slave;ID=000301;METER=0000004f;
20;DA;Slave;ID=000301;METER=00000000;
20;DB;Slave;ID=000301;METER=00000048;
20;DC;Slave;ID=000301;METER=00000073;
20;DD;Slave;ID=000301;METER=00000000;
20;DE;Slave;ID=000301;METER=00000046;
20;DF;Slave;ID=000301;METER=00000000;
20;E0;Slave;ID=000301;METER=00000052;
20;E1;Slave;ID=000301;METER=00000045;
20;E2;Slave;ID=000301;METER=0000003a;
20;E3;Slave;ID=000301;METER=00000020;
20;E4;Slave;ID=000301;METER=0000003d;
20;E5;Slave;ID=000301;METER=00000000;
20;E6;Slave;ID=000301;METER=0000002b;
20;E7;Slave;ID=000301;METER=0000004c;
20;E8;Slave;ID=000301;METER=00000015;
20;E9;Slave;ID=000301;METER=0000004b;
20;EA;Slave;ID=000301;METER=0000001b;
20;EB;Slave;ID=000301;METER=00000035;
20;EC;Slave;ID=000301;METER=0000000d;
20;ED;Slave;ID=000301;METER=00000014;
20;EE;Slave;ID=000301;METER=00000017;
20;EF;Slave;ID=000301;METER=0000002c;
20;F0;Slave;ID=000301;METER=00000093;
20;F1;Slave;ID=000301;METER=00000000;
20;F2;Slave;ID=000301;METER=00000068;
20;F3;Slave;ID=000301;METER=00000000;
20;F4;Slave;ID=000301;METER=00000000;
20;F5;Slave;ID=000301;METER=0000004b;
20;F6;Slave;ID=000301;METER=00000000;
20;F7;Slave;ID=000301;METER=00000086;
20;F8;Slave;ID=000301;METER=00000045;
20;F9;Slave;ID=000301;METER=00000000;
20;FA;Slave;ID=000301;METER=00000066;
20;FB;Slave;ID=000301;METER=00000000;
20;FC;Slave;ID=000301;METER=0000005f;
20;FD;Slave;ID=000301;METER=00000000;
20;FE;Slave;ID=000301;METER=0000007a;
20;FF;Slave;ID=000301;METER=00000000;
20;00;Slave;ID=000301;METER=00000075;
20;01;Slave;ID=000301;METER=00000000;
20;02;Slave;ID=000301;METER=00000061;
20;03;Slave;ID=000301;METER=00000000;
20;04;Slave;ID=000301;METER=0000003d;
20;05;Slave;ID=000301;METER=00000000;
20;06;Slave;ID=000301;METER=0000005f;
20;07;Slave;ID=000301;METER=00000000;
20;08;Slave;ID=000301;METER=00000040;
20;09;Slave;ID=000301;METER=0000003a;
20;0A;Slave;ID=000301;METER=00000061;
20;0B;Slave;ID=000301;METER=0000004f;
20;0C;Slave;ID=000301;METER=00000000;
20;0D;Slave;ID=000301;METER=00000040;
20;0E;Slave;ID=000301;METER=0000002b;
20;0F;Slave;ID=000301;METER=00000048;
20;10;Slave;ID=000301;METER=0000003e;
20;11;Slave;ID=000301;METER=00000033;
20;12;Slave;ID=000301;METER=00000023;
20;13;Slave;ID=000301;METER=0000005e;
20;14;Slave;ID=000301;METER=00000016;
20;15;Slave;ID=000301;METER=0000000f;
20;16;Slave;ID=000301;METER=00000016;
20;17;Slave;ID=000301;METER=00000057;
20;18;Slave;ID=000301;METER=0000004f;
20;19;Slave;ID=000301;METER=00000081;
20;1A;Slave;ID=000301;METER=0000002a;
20;1B;Slave;ID=000301;METER=00000000;
20;1C;Slave;ID=000301;METER=00000020;
20;1D;Slave;ID=000301;METER=00000026;
20;1E;Slave;ID=000301;METER=00000017;
20;1F;Slave;ID=000301;METER=00000016;
20;20;Slave;ID=000301;METER=00000016;
20;21;Slave;ID=000301;METER=00000014;
20;22;Slave;ID=000301;METER=00000028;
20;23;Slave;ID=000301;METER=0000001b;
20;24;Slave;ID=000301;METER=00000019;
20;25;Slave;ID=000301;METER=00000013;
20;26;Slave;ID=000301;METER=00000030;
20;27;Slave;ID=000301;METER=0000001d;
20;28;Slave;ID=000301;METER=00000017;
20;29;Slave;ID=000301;METER=0000001f;
20;2A;Slave;ID=000301;METER=0000002c;
20;2B;Slave;ID=000301;METER=00000017;
20;2C;Slave;ID=000301;METER=00000017;
20;2D;Slave;ID=000301;METER=00000014;
20;2E;Slave;ID=000301;METER=00000017;
20;2F;Slave;ID=000301;METER=00000023;
20;30;Slave;ID=000301;METER=0000001c;
20;31;Slave;ID=000301;METER=00000018;
20;32;Slave;ID=000301;METER=0000001a;
20;33;Slave;ID=000301;METER=00000021;
20;34;Slave;ID=000301;METER=00000037;
20;35;Slave;ID=000301;METER=00000031;
20;36;Slave;ID=000301;METER=00000053;
20;37;Slave;ID=000301;METER=00000027;
20;38;Slave;ID=000301;METER=00000000;
20;39;Slave;ID=000301;METER=0000006c;
20;3A;Slave;ID=000301;METER=00000011;
20;3B;Slave;ID=000301;METER=0000003f;
20;3C;Slave;ID=000301;METER=00000041;
20;3D;Slave;ID=000301;METER=00000016;
20;3E;Slave;ID=000301;METER=00000015;
20;3F;Slave;ID=000301;METER=00000023;
20;40;Slave;ID=000301;METER=0000003e;
20;41;Slave;ID=000301;METER=0000004f;
20;42;Slave;ID=000301;METER=00000023;
20;43;Slave;ID=000301;METER=00000048;
20;44;Slave;ID=000301;METER=00000055;
20;45;Slave;ID=000301;METER=00000020;
20;46;Slave;ID=000301;METER=0000009a;
20;47;Slave;ID=000301;METER=00000016;
20;48;Slave;ID=000301;METER=0000006c;
20;49;Slave;ID=000301;METER=0000001c;
20;4A;Slave;ID=000301;METER=0000001e;
20;4B;Slave;ID=000301;METER=0000005b;
20;4C;Slave;ID=000301;METER=00000038;
20;4E;Slave;ID=000301;METER=00000049;
20;4F;Slave;ID=000301;METER=00000050;
20;50;Slave;ID=000301;METER=0000003d;
20;51;Slave;ID=000301;METER=00000000;
20;52;Slave;ID=000301;METER=00000059;
20;53;Slave;ID=000301;METER=0000003b;
20;54;Slave;ID=000301;METER=00000034;
20;55;Slave;ID=000301;METER=0000003d;
20;56;Slave;ID=000301;METER=00000000;
20;57;Slave;ID=000301;METER=00000053;
20;58;Slave;ID=000301;METER=0000003c;
20;59;Slave;ID=000301;METER=0000006b;
20;5A;Slave;ID=000301;METER=00000000;
20;5B;Slave;ID=000301;METER=0000005b;
20;5C;Slave;ID=000301;METER=00000043;
20;5D;Slave;ID=000301;METER=0000002a;
20;5E;Slave;ID=000301;METER=00000022;
20;5F;Slave;ID=000301;METER=00000058;
20;60;Slave;ID=000301;METER=0000004b;
20;61;Slave;ID=000301;METER=00000000;
20;62;Slave;ID=000301;METER=00000038;
20;63;Slave;ID=000301;METER=00000000;
20;64;Slave;ID=000301;METER=0000005d;
20;65;Slave;ID=000301;METER=00000030;
20;66;Slave;ID=000301;METER=00000000;
20;67;Slave;ID=000301;METER=00000033;
20;68;Slave;ID=000301;METER=0000005c;
20;69;Slave;ID=000301;METER=0000005b;
20;6A;Slave;ID=000301;METER=00000000;
20;6B;Slave;ID=000301;METER=0000001d;
20;6C;Slave;ID=000301;METER=0000004b;
20;6D;Slave;ID=000301;METER=00000041;
20;6E;Slave;ID=000301;METER=0000003b;
20;6F;Slave;ID=000301;METER=00000021;
20;70;Slave;ID=000301;METER=00000018;
20;71;Slave;ID=000301;METER=00000015;
20;72;Slave;ID=000301;METER=00000024;
20;73;Slave;ID=000301;METER=0000001b;
20;74;Slave;ID=000301;METER=00000018;
20;75;Slave;ID=000301;METER=00000016;
20;76;Slave;ID=000301;METER=0000002a;
20;77;Slave;ID=000301;METER=00000024;
20;78;Slave;ID=000301;METER=00000015;
20;79;Slave;ID=000301;METER=0000001a;
20;7A;Slave;ID=000301;METER=00000019;
20;7B;Slave;ID=000301;METER=00000017;
20;7C;Slave;ID=000301;METER=00000012;
20;7D;Slave;ID=000301;METER=00000017;
20;7E;Slave;ID=000301;METER=00000028;
20;7F;Slave;ID=000301;METER=0000008a;
20;80;Slave;ID=000301;METER=00000000;
20;81;Slave;ID=000301;METER=00000035;
20;82;Slave;ID=000301;METER=0000004a;
20;83;Slave;ID=000301;METER=00000000;
20;84;Slave;ID=000301;METER=00000065;
20;85;Slave;ID=000301;METER=00000057;
20;86;Slave;ID=000301;METER=00000000;
20;87;Slave;ID=000301;METER=0000003a;
20;88;Slave;ID=000301;METER=00000044;
20;89;Slave;ID=000301;METER=00000000;
20;8A;Slave;ID=000301;METER=00000072;
20;8B;Slave;ID=000301;METER=00000000;
20;8C;Slave;ID=000301;METER=00000082;
20;8D;Slave;ID=000301;METER=00000000;
20;8E;Slave;ID=000301;METER=00000085;
20;8F;Slave;ID=000301;METER=00000000;
20;90;Slave;ID=000301;METER=00000077;
20;91;Slave;ID=000301;METER=00000000;
20;92;Slave;ID=000301;METER=00000074;
20;93;Slave;ID=000301;METER=00000000;
20;94;Slave;ID=000301;METER=0000005d;
20;95;Slave;ID=000301;METER=00000000;
20;96;Slave;ID=000301;METER=00000079;
20;97;Slave;ID=000301;METER=00000000;
20;98;Slave;ID=000301;METER=0000005e;
20;99;Slave;ID=000301;METER=00000000;
20;9A;Slave;ID=000301;METER=00000069;
20;9B;Slave;ID=000301;METER=0000005f;
20;9D;Slave;ID=000301;METER=00000041;
20;9E;Slave;ID=000301;METER=0000005c;
20;9F;Slave;ID=000301;METER=00000000;
20;A0;Slave;ID=000301;METER=00000041;
20;A1;Slave;ID=000301;METER=00000066;
20;A2;Slave;ID=000301;METER=0000003a;
20;A3;Slave;ID=000301;METER=0000005f;
20;A4;Slave;ID=000301;METER=00000054;
20;A5;Slave;ID=000301;METER=00000033;
20;A6;Slave;ID=000301;METER=00000050;
20;A7;Slave;ID=000301;METER=00000042;
20;A8;Slave;ID=000301;METER=00000000;
20;A9;Slave;ID=000301;METER=00000051;
20;AA;Slave;ID=000301;METER=00000052;
20;AB;Slave;ID=000301;METER=00000000;
20;AC;Slave;ID=000301;METER=00000052;
20;AD;Slave;ID=000301;METER=00000046;
20;AE;Slave;ID=000301;METER=00000000;
20;AF;Slave;ID=000301;METER=0000003d;
20;B0;Slave;ID=000301;METER=0000001b;
20;B1;Slave;ID=000301;METER=0000002b;
20;B2;Slave;ID=000301;METER=0000003d;
20;B3;Slave;ID=000301;METER=00000000;
20;B4;Slave;ID=000301;METER=00000059;
20;B5;Slave;ID=000301;METER=0000003a;
20;B6;Slave;ID=000301;METER=00000000;
20;B7;Slave;ID=000301;METER=0000004f;
20;B8;Slave;ID=000301;METER=00000063;
20;B9;Slave;ID=000301;METER=00000000;
20;BA;Slave;ID=000301;METER=0000004a;
20;BB;Slave;ID=000301;METER=00000000;
20;BC;Slave;ID=000301;METER=0000006d;
20;BD;Slave;ID=000301;METER=00000000;
20;BE;Slave;ID=000301;METER=0000006e;
20;BF;Slave;ID=000301;METER=00000000;
20;C0;Slave;ID=000301;METER=0000005f;
20;C1;Slave;ID=000301;METER=00000000;
20;C2;Slave;ID=000301;METER=0000005a;
20;C3;Slave;ID=000301;METER=00000000;
20;C4;Slave;ID=000301;METER=00000088;
20;C5;Slave;ID=000301;METER=00000000;
20;C6;Slave;ID=000301;METER=00000058;
20;C7;Slave;ID=000301;METER=00000000;
20;C9;Slave;ID=000301;METER=00000060;
20;CB;Slave;ID=000301;METER=00000044;
20;CC;Slave;ID=000301;METER=00000000;
20;CD;Slave;ID=000301;METER=0000008f;
20;CE;Slave;ID=000301;METER=0000004c;
20;D0;Slave;ID=000301;METER=00000038;
20;D1;Slave;ID=000301;METER=0000003f;
20;D2;Slave;ID=000301;METER=00000000;
20;D3;Slave;ID=000301;METER=00000045;
20;D4;Slave;ID=000301;METER=0000001c;
20;D5;Slave;ID=000301;METER=00000056;
20;D7;Slave;ID=000301;METER=00000046;
20;D8;Slave;ID=000301;METER=0000005e;
20;D9;Slave;ID=000301;METER=00000000;
20;DA;Slave;ID=000301;METER=00000075;
20;DB;Slave;ID=000301;METER=00000000;
20;DC;Slave;ID=000301;METER=0000007b;
20;DE;Slave;ID=000301;METER=00000000;
20;DF;Slave;ID=000301;METER=0000003c;
20;E0;Slave;ID=000301;METER=0000004f;
20;E1;Slave;ID=000301;METER=00000000;
20;E2;Slave;ID=000301;METER=00000048;
20;E3;Slave;ID=000301;METER=0000003a;
20;E4;Slave;ID=000301;METER=00000000;
20;E5;Slave;ID=000301;METER=00000041;
20;E6;Slave;ID=000301;METER=00000000;
20;E7;Slave;ID=000301;METER=00000064;
20;E8;Slave;ID=000301;METER=00000051;
20;E9;Slave;ID=000301;METER=00000000;
20;EA;Slave;ID=000301;METER=0000005c;
20;EB;Slave;ID=000301;METER=0000004e;
20;EC;Slave;ID=000301;METER=00000000;
20;ED;Slave;ID=000301;METER=0000003d;
20;EE;Slave;ID=000301;METER=00000000;
20;EF;Slave;ID=000301;METER=0000007b;
20;F0;Slave;ID=000301;METER=00000000;
20;F1;Slave;ID=000301;METER=00000078;
20;F2;Slave;ID=000301;METER=00000000;
20;F3;Slave;ID=000301;METER=0000006e;
20;F5;Slave;ID=000301;METER=0000004d;
20;F6;Slave;ID=000301;METER=00000051;
20;F7;Slave;ID=000301;METER=00000000;
20;F8;Slave;ID=000301;METER=0000003e;
20;FC;Slave;ID=000301;METER=00000082;
20;FE;Slave;ID=000301;METER=00000079;
20;00;Slave;ID=000301;METER=0000003e;
20;01;Slave;ID=000301;METER=00000039;
20;02;Slave;ID=000301;METER=0000003f;
20;04;Slave;ID=000301;METER=00000044;
20;05;Slave;ID=000301;METER=0000004a;
20;06;Slave;ID=000301;METER=0000005a;
20;07;Slave;ID=000301;METER=0000003e;
20;08;Slave;ID=000301;METER=00000000;
20;09;Slave;ID=000301;METER=00000013;
20;0A;Slave;ID=000301;METER=00000062;
20;0B;Slave;ID=000301;METER=00000000;
20;0C;Slave;ID=000301;METER=00000061;
20;0D;Slave;ID=000301;METER=00000000;
20;0E;Slave;ID=000301;METER=0000005f;
20;0F;Slave;ID=000301;METER=00000000;
20;10;Slave;ID=000301;METER=00000092;
20;11;Slave;ID=000301;METER=00000000;
20;12;Slave;ID=000301;METER=00000077;
20;13;Slave;ID=000301;METER=00000032;
20;14;Slave;ID=000301;METER=00000000;
20;15;Slave;ID=000301;METER=0000004d;
20;16;Slave;ID=000301;METER=00000000;
20;17;Slave;ID=000301;METER=00000062;
20;18;Slave;ID=000301;METER=0000003e;
20;19;Slave;ID=000301;METER=00000000;
20;1A;Slave;ID=000301;METER=00000046;
20;1B;Slave;ID=000301;METER=0000003b;
20;1C;Slave;ID=000301;METER=00000000;
20;1D;Slave;ID=000301;METER=00000058;
20;1E;Slave;ID=000301;METER=00000000;
20;1F;Slave;ID=000301;METER=0000004a;
20;20;Slave;ID=000301;METER=00000043;
20;21;Slave;ID=000301;METER=00000000;
20;22;Slave;ID=000301;METER=00000065;
So as far as I can tell pretty good. Max is 220 (dec.) Note my meter runs 187 turns in a kWh.
Anyone know why I get the enormous counts as seen in the picture of my previous post above? Would the zero counter be a problem?
Regards,
Marco
