KNX interface
multinet
KNX interface
Post by multinet »
Hello
I've a heater/cooler using a AIRZONE (http://www.airzone.es) to set temperature n each room
It is possible to add a KNX gateway to my AIRZONE system (http://www.airzonefrance.fr/knx.php) in order to control it by a third party system.
I would like to know if it is possible to add a KNX hardware to my raspberry in order to control my temperature via domoticz.
Any help welcome
Multinet
PI 2 - Domoticz 2021.1
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver (5 DIO 54755 + 2 DIO 54756 + 3 DIO 54798)
Z-Wave.Me ZME_UZB1 USB Stick (6 FGSD002 + 2 FGRM222 + 1 FGS223 + 1 FGMS001-ZW5 + 1 FGRGBWM441 + 1 FGBS001 + 2 FGFS101)
6 sondes DS18B20
Skippiemanz
Domoticz version: 4.10233
Re: KNX interface
Post by Skippiemanz »
I would be interested in this also...
Verstuurd vanaf mijn SM-G925F met Tapatalk
multinet
Re: KNX interface
Post by multinet »
Hello
I found a solution without Knx and just a relay board
Just making some tests before describing it
Are you still interested ?
6 sondes DS18B20
v40jlt4
Domoticz version: 2021.1
Re: KNX interface
Post by v40jlt4 »
multinet wrote: Tuesday 03 April 2018 16:43 ...Are you still interested ?
If not, then I am!
I just bought a house that turns out to be loaded with hager knx-rf switches which I'd love to control via domoticz.
But trying to search KNX is already near impossible :-)
So sharing any KNX-RF related knowledge would be welcome.
Skippiemanz
Re: KNX interface
v40jlt4 wrote: Tuesday 24 April 2018 23:20
If not, then I am!
No trying to be negative about domoticz but why not use the KNX(RF)? add a new IP Gateway like xxter or Pairott and your off to go! I hope ou got the KNX Project file with the purchase of the house..
papoo
Re: KNX interface
Post by papoo »
v40jlt4
Re: KNX interface
Post by v40jlt4 »
Skippiemanz wrote: Wednesday 25 April 2018 20:46 .....
Thanks for the heads up. In my current house I use z-wave stuff & domoticz. In the new house there are also multiple somfy blinds for which I bought a RFXtrx433E. I was hoping to make it all (including the KNX stuff) come together into domoticz.
But I'll look into all options.
And unfortunately, but no, no project files or any info on the KNX install :-(
Thanks again
PS. some related stuff found here:
http://selfbus.myxwiki.org/xwiki/bin/vi ... FT12_Raspi
http://www.knx-forum.be/viewtopic.php?f ... 8&start=10
https://michlstechblog.info/blog/raspbe ... with-knxd/
Skippiemanz
Re: KNX interface
Perhaps there is a usb stick somewhere with the project file in the utility closet?? Without it it's gonna be a struggle to figure everything out.
I have some installs where xxter send out a json command to Domoticz.
Otherwise a relay soldered to the somfy remote and controlled by knx is also an option.
v40jlt4
Re: KNX interface
Post by v40jlt4 »
Skippiemanz wrote: Thursday 10 May 2018 17:19 Perhaps there is a usb stick somewhere with the project file in the utility closet?? ...
Found it, unfortunately it's a 16MB SmartMedia memory card that fits a hager TX100 programmer.
Luckily, my friends from aliexpress have a card-reader that also reads SM for just €8.51. I'll be back in a few weeks.
Furthermore, I'm going to search for an (affordable) KNX-USB interface and try to go from there. E.g. hook up a PC/rPi
Skippiemanz
Re: KNX interface
Nice!
Ive got a spare ets 5 lite license if you're interested.
And a weinzerl usb gateway. Even if you like the xxter gateway i can get you a good deal on that.
v40jlt4
Re: KNX interface
Post by v40jlt4 »
Skippiemanz wrote: Thursday 17 May 2018 22:09 .....And a weinzerl usb gateway.....
Thx,
About the Weinzierl, which one is it?
Skippiemanz
Re: KNX interface
https://goo.gl/images/LhFGwk
The Weinzierl 332
v40jlt4
Re: KNX interface
Post by v40jlt4 »
Got my SM card reader today.
The SM card has a view .bin files:
CONN_000.BIN
INST_000.BIN
CHAN_000.BIN
PROD_000.BIN
CONFIG.000
Is this something that ETS would read?
I'd say no if I check this link:
https://www.knx.org/ie/software/ets/man ... /index.php
USB stick looks interesting. Would this, combined with ETS be able to "read" the current configuration? Or do I need those .bin files, which seem hager specific to me.
The internet is not really helping me in getting info regarding those files.
The search continues...
Skippiemanz
Re: KNX interface
v40jlt4 wrote:Got my SM card reader today.
CONN_000.BIN
INST_000.BIN
CHAN_000.BIN
PROD_000.BIN
CONFIG.000
Nope that doesnt look like ets files.
The ets and interface wil show you the group adressen but not the names and parameters of the knx device so pretty useless im afraid.
