ONVIF RTSP camera support
panser
Post by panser »
Would really like to have ONVIF camera support directly in Domoticz.
ONVIF (Open Network Video Interface Forum) is a global and open industry forum with the goal to facilitate the development and use of a global open standard for the interface of physical IP-based security products. Or in other words, to create a standard for how IP products within video surveillance and other physical security areas can communicate with each other
[url]http://www.oo%20nvif.org/specs/stream/ONVIF-Streaming-Spec-v210.pdf[/url]
With that said, I have no idea how easy/difficult it would be to code and implement this.
Heisenberg
Re: ONVIF RTSP camera support
Post by Heisenberg »
+1
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
daryah
Post by daryah »
+1
exploring installing zoneminder on same pi for its better support of camera and other features. However, just came across the fact that I have to get apache co-existing with Domoticz and not sure how to go about that...
setup: Domoticz@SynNAS; RFXTRX 433; Response E. Alarm, Teqin IP PTZ Camera, Mercury Socket, 1byOne Chime; SSE smart meter
plan: Lightwave RF Dimmers & PIR, integ. evohome heating
pj-r
Domoticz version: V3.8650
Post by pj-r »
daryah wrote:+1
Just setup it listening to other port than domoticz.
bobdvb
Post by bobdvb »
+1 for this
I've been looking at replacing an old Samsung DVR with ONVIF cameras and now that I have Domoticz it looks like I could have a good unified interface. But without ONVIF support things aren't great, so I would love it to support this.
BarryT
Domoticz version: 2024.3
Post by BarryT »
I think it is not that easy..
Onvif uses a complicated protocol that has to be implemented in the software/hardware of a raspberry/linux core/others..
But it is not impossible, as so far someone has made a onvif camera from a raspberry, so i guess a client is easier to do :)
http://www.instructables.com/id/How-to- ... Pi-into-a/
Anyway, +1 for the (multi camera) onvif support!
Then we can build our own NVR, and that will open new possibilities ofcourse..
Another option is to import a sort of client software, that support multi camera.
It should be great when there is a on/off button, in domoticz, wich send a "now record" to a camera, when a doorbell is ringing, or a door goes open for example.
Then we don't need a external nvr anymore..
Ofcourse, if you want to do "motion detection" you still need another nvr, because it often uses a lot of cpu.
dba59
Domoticz version: last
Post by dba59 »
+1
roblom
Post by roblom »
+1
Verstuurd vanaf mijn HTC One M9 met Tapatalk
simon_rb
Post by simon_rb »
+1
hasan
Post by hasan »
+1
kubrik
Post by kubrik »
+1
Ubuntu 20.04 on ACEPC AK1 (previously RPi3b+)
Z-Stick Gen5, RFXtrx433E, Philips HUE Bridge, Yeelight, ESP8266 NodeMCU, Broadlink RM
dZvents, bash, php, Node-RED
woody4165
Post by woody4165 »
+1
mKotek
Post by mKotek »
+1
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
PDGN
Post by PDGN »
+1
jprod
Domoticz version: 3.5877
Post by jprod »
Meeki
Post by Meeki »
I found a workaround for ONVIF RTSP camera's
I posted a howto here: http://domoticz.com/forum/viewtopic.php?f=35&t=15444
ArieKanarie
Post by ArieKanarie »
The second url indeed helped me finding de snapshoturl for my RTSP/ONVIF camera :P
Good tip!
Attention: If your camera uses another port for the ONVIF protocol, don't forget to ad this port to the url in the command.
For the record: Owners of a FunXWE (FS02-0) IP camera can use the snapshot url: http://<Camera_ip>/web/cgi-bin/hi3510/snap.cgi?&-getstream&-sn
(Manufacturer/Model: RTT-5300)
mikkel75
Post by mikkel75 »
+1
Andree
Post by Andree »
+1
miljume
Domoticz version: v3.8742
Post by miljume »
+1
