Option to combine or split values from combined TEM/HUM sensors
Posted: Wednesday 16 March 2016 19:30
by miljume
I have created a sensor (MySensors) with both one DHT22 giving both temperature and humidity and one DS18B20 that is placed at another location (cable connected)
Currently Domoticz with MySensors gateway creates two sensor devices for this setup where the humidity value is added to both devices. The problem with this is that the humidity shown for DS18B20 sensor is the value registered at the location of the DHT22 sensor
I suggest an option where you on a node level could choose if the temp & humidity value should be combined in one device or splitted into two devices
