PIR81K PIR Sensor
four2six
PIR81K PIR Sensor
Post by four2six »
Does anyone have any experiences with this Passive Infrared Detector?
http://de.aliexpress.com/item/Free-Ship ... 07324.html
RFXtrx433 doesn't seem to pick it up... and I have no idea if it makes sense to start and dig deeper. Any ideas appreciated.
dijkdj
Re: PIR81K PIR Sensor
Post by dijkdj »
I have one that look exactly the same. It works in Domoticz with RFX433E
Jumper3126
Post by Jumper3126 »
Got one that looks the same as well, even is "imune" for animals, although this is not waterproof. It does work well with RFX433E
four2six
Post by four2six »
how did you get that one to work with it? did RFX433E pick it up automatically?
sincze
Domoticz version: 2024.4
Post by sincze »
Just check the chipset of the device. With 4 jumpers you can make it respond to arc commands :)
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
four2six
Post by four2six »
thanks, but no jumpers on the board i have. At least none that I would recognise as such.
Treve
Domoticz version: v4.11474
Post by Treve »
I also bought from this seller, I asked a 433MHz version with a sc2262 chip.
http://nl.aliexpress.com/item/Free-Ship ... 07324.html
the device presents itself in Domoticz as "Lightning 4" and "PT2262" and works perfect.
i did not use the L H pins (adresses) on the leftside of the board, only a jumper for frequency selection.
Pir board.jpg (145.58 KiB) Viewed 2099 times
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
b_weijenberg
Post by b_weijenberg »
You have the option to receive this sensor as ARC sensor if you configure L H
See http://www.domoticz.com/forum/viewtopic ... 44&p=72133
RFX-433, RFX-433EMC, RFX-868
Treve
Post by Treve »
Thanks for reporting B.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
