dzVents presence detection and security alarms
Posted: Wednesday 16 March 2016 9:47
by commodore white
The following code implements a presence detector based on the proximity of (android) mobile phones. Unusually, its written using features found in the dzVents package found here:
http://www.domoticz.com/forum/viewtopic ... 23&t=10834
Enjoy.
I've taken the liberty of publishing my security alarm code having found things so easy to write using dzVents compared to writing in native LUA.
Suggestions for improvements would be appreciated.
--[[ lua/scripts/phones.lua by commodore white
This dzVents script implements an android phone presence detector using the
Domoticz System Alive Checker (Ping) feature.
For each phone being monitored, you need two virtual devices, one that you bind to the System
Alive Checker, and another that keeps you informed of the phones proximity. I needed the second
because our phones kept losing and regaining connectivity as we moved around the house or we went outside
for a few minutes perhaps to the washing line.
The script is in two parts, the first responds to pings while the second implements a 'grace period' during
which time a phone can be out of earshot for a short while without raising the alarm.
The script also maintains another virtual device called "AnyPhone" which is On whenever any phone is
in reach.
My virtual devices are called:
Peter and pingPeter
Rita  and pingRita, and
AnyPhone
... that is, 2n+1 virtual devices in total.
   on = { "ping*", "timer" },
   active = true,
   execute = function(domoticz, _pingPhone)
   local phone
   local pingPhone
   local GRACE = 10
   local lost_or_found
   local AnyPhone
   local _AnyPhone
   local _phone
   local _pingPhone
   printf = function(s,...) return print("dzVents Phones: " .. s:format(...)) end
   _AnyPhone = domoticz.devices["AnyPhone"]
   if _pingPhone ~= nil then
     phone = _pingPhone.name:sub(5,99)
     _phone = domoticz.devices[phone]
     if    _pingPhone.state == "On" and _phone.state == "Off"
     then  _phone.switchOn()
           if _AnyPhone.state == "Off" then _AnyPhone.switchOn() end
     AnyPhone = "Off" -- assume no phones found
     domoticz.devices.forEach(function(_pingPhone)
  	   if (_pingPhone.name:sub(1,4) == "ping") then
          phone = _pingPhone.name:sub(5,99)               _phone = domoticz.devices[phone]
          m_phone     = _phone.lastUpdate.minutesAgo      m_pingPhone = _pingPhone.lastUpdate.minutesAgo
          if _phone.state == "On" then           -- recently seen
            if    _pingPhone.state == "Off"      -- but currently not seen
            and   m_pingPhone > GRACE            -- and has been so for several minutes
            then  _phone.switchOff()
                  printf("%s's phone lost %um ago", phone, m_pingPhone)
                  printf("%s's phone found %uh %um ago", phone, m_phone/60, m_phone%60)
                  AnyPhone = "On"
             if _pingPhone.state == "On" and _phone.state ~= "On" then _phone.switchOn() end -- incase the ping was missed
             printf("%s's phone lost %uh %um ago", phone, (m_phone+GRACE)/60, (m_phone+GRACE)%60)
          end -- if phone.state
  	 end) -- for each
    if AnyPhone ~= _AnyPhone.state then _AnyPhone.setState(AnyPhone) end
    end -- if ping
  end -- function
} -- return
I've re-uploaded the phones script since I had foolishly tainted it with unrelated functionality, namely issuing a notification message.I've put the annexed functionality into a separate script below. Not great but it works.
-- proximity.lua
	active = true,
	on = { 'Peter', "Rita"},
	execute = function(domoticz, phone)
		if      phone.state  == "On"
    and     domoticz.security == domoticz.SECURITY_DISARMED
    then    domoticz.notify(phone.name .. " has arrived home", '',
				      domoticz.PRIORITY_EMERGENCY,
				      domoticz.SOUND_SIREN)
            domoticz.notify(phone.name .. " has arrived home - ALARMS ON", '',
	end -- function
Security Panel handler in dzVents
--[[ /lua/scripts/security.lua
This script handles the Security Panel. When security is enabled it first checks if any doors or windows
are alarmed and reports it via messaging.
Shortly after security is enabled, the alarms are enabled and disabled immediately security is disabled.
You'll need to create a virtual device called AlarmsEnabled to use this script.
	active = true,
	on = { "Security Panel", "AlarmsEnabled",
         "timer" },
	execute = function(domoticz,_device)
    DELAY = 30
    _AlarmsEnabled = domoticz.devices["AlarmsEnabled"]
    -- If the Security Panel has changed state
    if    _device == domoticz.devices["Security Panel"]
    then
         if    domoticz.security == domoticz.SECURITY_DISARMED
         then
             if    _AlarmsEnabled.state == "On"      -- prevent spurious disarm events
             then  _AlarmsEnabled.switchOff() end
         -- check if any doors or windows are alarmed
              openings = 0
-- disregard perimeter sensors for now
              domoticz.devices.forEach(function(_sensor)
                if    (_sensor.name:sub(1,3) == "msc")
                and   _sensor.state == "Alarm"
                then  openings = openings + 1 end
              end) -- for each
-- perimeter alarms
              then  message = "Alarms already enabled"
              else  message = "Alarms enabled in " .. DELAY .. "s" end
              if    openings == 0
              then  domoticz.notify("Property seems secure", message)
              else  domoticz.notify(openings .. " openings need securing", message) end
              -- schedule alarms to be enabled in DELAY seconds if its not already On
              if    _AlarmsEnabled.state ~= "On"
              then  _AlarmsEnabled.switchOn().after_sec(DELAY) end
          end -- security panel state is disarmed
    end -- if security panel state changed
    -- If the Security Panel state was changed to DISARMED while the alarms are waiting
    -- to be enabled, switch Off the alarms. Shame there's not a cancel function.
    -- Notify everyone when alarms have been enabled or disabled
    if    _device == _AlarmsEnabled
    then
          if    _device.state == "On"
          then  domoticz.notify("Alarms enabled", '')
          else  domoticz.notify("Alarms disabled", '') end
  end -- function
Perimeter and internal detector handling in dzVents
--[[ /lua/scripts/motion.lua by commodore white
Report PIR and door/window opening/closing events unless alarm reporting is disabled
sounds a fire alarm if security is high unless a registered phone is nearby
          disarmed or
           suspended     armed home       armed away
internal  |  No              No          Notify+Siren
perimeter |  No            Notify        Notify+Siren
  active = true,
	on = { 'pir*',    -- internal detectors
        "msc*"    -- perimeter detectors
	execute = function(domoticz, _detector)
-- test mode: no alarms if someone is at home, comment out for normal operation
--    if domoticz.devices["AnyPhone"].state == "On" then return end
    if    domoticz.security == domoticz.SECURITY_DISARMED then return end         -- don't report if security is DISARMED
    if    domoticz.devices["AlarmsEnabled"].state == "Off" then return end        -- ... or if alarms are temporarily suspended
    if   _detector.name:sub(1,3) == "pir"                                         -- ignore internal detectors in
    and  domoticz.security == domoticz.SECURITY_ARMEDHOME                         -- low security mode
    then
          return
    domoticz.notify('SECURITY BREACH', _detector.name:sub(4), domoticz.PRIORITY_EMERGENCY, domoticz.SOUND_SIREN)
    if    domoticz.security == domoticz.SECURITY_ARMEDAWAY                        -- in high security mode
    and   domoticz.devices["AnyPhone"].state == "Off"                             -- check no one is at home
    then
          domoticz.devices["Siren"].switchOn()                                	-- then set off the siren
	end -- execute
Fire Alarm notification
--[[ /lua/scripts/fire.lua by commodore white
Notifies which alarm has been triggered
All fire alarms have names that begin with the characters "fire", for example, fireLounge, fireGarage, etc
	active = true,
	on = { "fire*" },
	execute = function(domoticz, _sounder)
    if _sounder.state == "On" then
       local DURATION = 40
       domoticz.notify("FIRE ALARM: " .. _sounder.name, '',
       domoticz.devices["Alarm"].switchOn()    -- turn on the notify system
    end -- if sounder On
	end -- function
Panic button notification
--[[ /lua/scripts/PanicButton.lua by commodore white
Always report panic button presses. There's one in my aged relatives bedroom (panicBedroom),
one in their bathroom (panicBathroom), and another by the front door (panicFrontDoor)
If any panic button is pressed, then the "Alarm" button is turned on.
  active = true,
	on = { 'panic*'},
	execute = function(domoticz, _panicbutton)
    local _alarm = domoticz.devices["Alarm"]                 -- Get id of alarm button
    domoticz.notify("PANIC BUTTON", _panicbutton.name:sub(6) .. ' button was pressed')
    if _alarm.state == "Off" then _alarm.switchOn() end      -- enable the Cancel Panic button
	end -- execute
Door bell button press notification. Needs to work with cameras.
--[[ /lua/scripts/doorbellpush.lua by commodore white
Notify if any door bell was pressed
Ignore multiple presses within a minute, you need a "BellPressed" variable for this
to work
  active = true,
	on = { 'bell*' },
	execute = function(domoticz, _bell)
    if    domoticz.variables['BellPressed'].lastUpdate.minutesAgo > 1
    then
          domoticz.notify("DOOR BELL", _bell.name:sub(5) .. ' bell was pressed')
  		    domoticz.variables['BellPressed'].set(0)
	end -- execute
Notification handler
--[[ /lua/scripts/Notify.lua by commodore white
      ['timer'] = 'every 5 minutes',
      "Alarm"
   active = true,
   execute = function(domoticz, _alarm)
      local DURATION = 20
      if    _alarm ~= nil
      then
            if    _alarm.state == "Off"          -- alarm just got cancelled
            then
 -- commandArray["OpenURL"]="http://192.168.1.22:8080/json.htm?type=command&param=resetsecuritystatus&idx=86&switchcmd=Normal"
                  domoticz.devices["fireLanding"].switchOff()
                  domoticz.notify("Alarm cancelled",' ')
          m_alarm = _alarm.lastUpdate.minutesAgo
          if     _alarm.state == "On"                            -- Alarm still active ?
          then                                                   -- If so, ...
                  if    m_alarm < DURATION
                  then
                        domoticz.notify ("Alarm raised " .. m_alarm .. "m ago", "Visit Control Panel to clear")
                        _alarm.switchOff()
       end -- end if alarm
   end -- execute
... and not a commandArray in sight!
Peter
