Last week, I added 2 Qubino ZMNHCD1 (ZWave+ Flush shutter) to my ZWave network without difficulties. Both devices seems to work well except they don't report their statuses, but fortunately there is a workarround thanks to forum users Egrerius and jvdz.
However, everytime I send a command manually or by script to these devices, I see these messages in the Domoticz log file:
2016-03-15 07:20:00.222 EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/lua/script_time_rolluikopen03.lua
2016-03-15 07:20:00.734 Activating Scene/Group: [Rolluiken_Voor]
2016-03-15 07:20:00.735 Activating Scene/Group Device: Rolluik_Living_Voor (On)
2016-03-15 07:20:00.736 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 2 (0x02)
2016-03-15 07:20:00.737 (ZWaveStick) Light/Switch (Rolluik_Living_Voor)
2016-03-15 07:20:00.813 (ZWaveStick) Light/Switch (Rolluik_Living_Voor)
2016-03-15 07:20:00.825 Activating Scene/Group Device: Rolluik_Bureel_Links (On)
2016-03-15 07:20:00.825 Delaying switch [Rolluik_Bureel_Links] action (Set Level) for 2 seconds
2016-03-15 07:20:00.886 Activating Scene/Group Device: Rolluik_Bureel_Rechts (On)
2016-03-15 07:20:00.886 Delaying switch [Rolluik_Bureel_Rechts] action (Set Level) for 4 seconds
2016-03-15 07:20:02.284 (ZWaveStick) Usage (Unknown)
2016-03-15 07:20:02.286 (ZWaveStick) Usage (Power Meter)
2016-03-15 07:20:02.963 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 5 (0x05)
2016-03-15 07:20:02.964 (ZWaveStick) Light/Switch (Rolluik_Bureel_Links)
2016-03-15 07:20:03.054 (ZWaveStick) Light/Switch (Rolluik_Bureel_Links)
2016-03-15 07:20:03.983 Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh05.sh
2016-03-15 07:20:15.152 Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh05.sh
2016-03-15 07:20:20.654 (ZWaveStick) Usage (Unknown)
2016-03-15 07:20:20.655 (ZWaveStick) Usage (Power Meter)
2016-03-15 07:20:22.584 (ZWaveStick) Light/Switch (Rolluik_Living_Voor)
2016-03-15 07:20:22.605 (ZWaveStick) Usage (Unknown)
2016-03-15 07:20:22.606 (ZWaveStick) Usage (Power Meter)
2016-03-15 07:20:23.444 (ZWaveStick) Light/Switch (Rolluik_Bureel_Links)
2016-03-15 07:20:24.453 Error, Node005, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL endpoint 1
2016-03-15 07:20:24.633 Always,
2016-03-15 07:20:24.633 Always, Dumping queued log messages
2016-03-15 07:20:24.634 Always,
2016-03-15 07:20:24.634 Always, End of queued log message dump
2016-03-15 07:20:26.533 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 6 (0x06)
2016-03-15 07:20:26.534 (ZWaveStick) Light/Switch (Rolluik_Bureel_Rechts)
2016-03-15 07:20:26.565 Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh05.sh
2016-03-15 07:20:26.624 (ZWaveStick) Light/Switch (Rolluik_Bureel_Rechts)
2016-03-15 07:20:37.894 Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh06.sh
2016-03-15 07:20:47.393 (ZWaveStick) Light/Switch (Rolluik_Bureel_Rechts)
2016-03-15 07:20:48.220 Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh06.sh
2016-03-15 07:20:48.403 Error, Node006, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL endpoint 1
2016-03-15 07:20:48.403 Always,
2016-03-15 07:20:48.403 Always, Dumping queued log messages
2016-03-15 07:20:48.404 Always,
2016-03-15 07:20:48.404 Always, End of queued log message dump
2016-03-15 07:20:59.563 Executing script: /volume1/@appstore/domoticz/var/scripts/refresh/refresh06.sh
I also tried user gizmocuz advice without change:
Is there anything else I can do?could you goto the openzwave setup, then from the dropdown groups/network
make sure only node 1 is in group 1/2/3
I'm on Synology DS213, Aeon Labs USB Z-Stick Gen5, Domoticz V3.4834/OpenZWave 1.4.77 (http://www.jadahl.com/)
