Control PiMusicbox with lua
Posted: Tuesday 15 March 2016 12:49
by Gijs69
I created this script to control my http://www.PiMusicbox.com with Domoticz.
-- Script to control my Pi Musicbox
-- Usage of a two Dummy devices: Selector (MusicBox radio) and Dimmer (MusicBox volue)
if devicechanged['MusicBox volume'] then
  if (devicechanged['MusicBox volume']=='Off') then
	os.execute('mpc --host=musicbox.local stop')
	print('Switch off Radio')
     	if (devicechanged['MusicBox volume']=='On') then
	   os.execute('mpc --host=musicbox.local play')
    	   print('Switch on Radio')
	   os.execute('mpc --host=musicbox.local volume '..otherdevices_svalues['MusicBox volume'])
	   print('Set volume to '..otherdevices_svalues['MusicBox volume'])
if (devicechanged['MusicBox radio']=='100% NL') then
	os.execute('mpc --host=musicbox.local clear')
	os.execute('mpc --host=musicbox.local add http://stream.100p.nl/100pctnl.mp3')
	os.execute('mpc --host=musicbox.local play 1')
	print('Switched Radio to 100% NL')
if (devicechanged['MusicBox radio']=='3FM Serious Radio') then
	os.execute('mpc --host=musicbox.local add http://icecast.omroep.nl/3fm-bb-mp3.m3u')
	print('Switched Radio to 3FM')
if (devicechanged['MusicBox radio']=='Studio Brussel') then
	os.execute('mpc --host=musicbox.local add http://mp3.streampower.be/stubru-high.mp3')
	print('Switched Radio to Studio Brussel')
if (devicechanged['MusicBox radio']=='Radio 538') then
	os.execute('mpc --host=musicbox.local add http://vip-icecast.538.lw.triple-it.nl/RADIO538_MP3.m3u')
	print('Switched Radio to Radio 538')
if (devicechanged['MusicBox radio']=='Sky radio') then
	os.execute('mpc --host=musicbox.local add http://8573.live.streamtheworld.com:80/SKYRADIO_SC')
	print('Switched Radio to Sky Radio')
Re: Control PiMusicbox with lua
Posted: Monday 09 January 2017 20:22
by Chiel
Hi Gijs, tried to use your script, but can you tell me which dummy devices I have to make and which names I have to give the lua script?
Created script_devices_musicbox_keuken.lua and put that in the lua scripts folder, created two dummy devices but in the logging I receive different kind of errors:
2017-01-09 20:21:47.817 Error: EventSystem: in /usr/local/domoticz/var/scripts/lua/script_device_musicbox_keuken.lua: ...moticz/var/scripts/lua/script_device_musicbox_keuken.lua:27: attempt to concatenate field 'MusicBox volume' (a nil value)
2017-01-09 20:21:47.832 Error: EventSystem: in /usr/local/domoticz/var/scripts/lua/script_device_musicbox_volume.lua: ...moticz/var/scripts/lua/script_device_musicbox_volume.lua:27: attempt to concatenate field 'MusicBox volume' (a nil value)
2017-01-09 20:21:47.781 (MusicBox) Light/Switch (MusicBox radio)
Could you please help me? Thnx!
Posted: Wednesday 18 January 2017 20:48
by elmortero
Hi gijs69,
Until I saw your post I only used local playlists, thanks to your script I now have a mix of playlist and streaming radio.
Thanks a lot!
I just finished a script that gets the currently playing track and updates it to a text sensor to display it in Domoticz.
Do you by chance know if there is a way to make mopidy/mpd perform an action when it starts a new track?
I would like to make it trigger a hidden switch which then triggers the script to get the song name.
This Lua script needs dzvents
	active = true,
			['timer'] = 'every minute'
	--[[script runs every minute, max delay in updating new song is 59 seconds (give or take :-) )
		I am looking for a way to make MPD trigger a (hidden) switch which then can trigger this script
		so the text sensor updates in real-time and this script will not run unnecessary
	-- persistent variable to store the song name so we can check if it is the same track playing
	data = {
        previous = {initial = nil}
	execute = function(domoticz)
	-- getting the song name if MPD uses other port number -p <portnumber> needs to be added
	local rawname = io.popen("mpc -h 192.168.1.12 current")
	local fullname = rawname:read("*a")
	rawname:close()
	-- cropping the song name to 25 characters (for later use in a text sensor)
	local currentsong = string.sub(fullname, 1, 25)
	-- read the name that was stored last time the script ran
	local prevsong = tostring(domoticz.data.previous)
	local disp = domoticz.devices['Playing']		-- declaring the name of the text sensor
	-- check if current song is different from the stored one
				if currentsong ~= prevsong then
				domoticz.log("Current song is : " ..currentsong, domoticz.LOG_INFO)  -- only needed while testing
	--[[ current song is not the same as previous stored one so we overwrite
		 the content of previous with the current song and update the text sensor with the current track
				domoticz.data.previous = currentsong
				disp.updateText(currentsong)
Posted: Saturday 29 July 2017 18:15
by Artemgy
Thanks for these Lua scripts, it's about time I rolled up my sleeves and did some real work integrating Domoticz and these look like a great start :)
If you are still looking for an alternative to polling MPD on a regular basis, then perhaps the MPC IDLE command will help.
mpc idle player # block until the player changes songs
mpc current     # outputs "Artist Name - Song Name" onto stdout
Credit - https://stackoverflow.com/a/34905959
Help and Syntax: https://www.musicpd.org/doc/protocol/co ... s_commands
This is supposed to work with the Mopidy implementation as well as Kellerman's classic MPD (the one most people use).
