Control your Aldi EasyHome robot vacuum cleaner
Posted: Monday 14 March 2016 19:47
by LouiS22
Hi!
With the help of gizmocuz's and blitzkneisser's sketches I was able to integrate Aldi's robot vacuum cleaner (model number KSR RVC3000) into Domoticz. This particual model has IR receiver and a remote to control it.
The challenge was the following:
1. the IR protocol is not common one, so had to use RAW values.
2. to start with the remote, you have assign the CLEAN command twice.
The basics are written in these topics:
http://domoticz.com/forum/viewtopic.php?f=42&t=7648
http://domoticz.com/forum/viewtopic.php?f=42&t=10678
Gizmocuz had the brilliant idea to assign a hash to the raw values. In theory one can use this method to control almost everything.
Below the working sketch, there's a 3 sec delay between the two CLEAN commands.
#include <MySensor.h>
#include <SPI.h>
#include <IRLib.h>
#include <avr/pgmspace.h>
int RECV_PIN = 8;
#define CHILD_1  3  // childId
IRsend irsend;
IRrecv irrecv(RECV_PIN);
IRdecode decoder;
IRdecodeHash Hash_Decoder;
//As some remotes could have different hashes for the same button (when they are not good received or other reasons)
//we only let the following hashes go through
#define MYCODES_NUM 6
#define MYCODES_LENGTH 24
const unsigned long myHashes[MYCODES_NUM] = {
  0x52A3E788,  // Be
const unsigned int myCodes[MYCODES_NUM][MYCODES_LENGTH] PROGMEM ={
  4520,4332,592,484,592,1572,600,512,564,1568,596,520,556,1576,596,488,584,472,4508,4332,596,516,564,1600,568,484,592,1576,592,488,592,1568,596,476,596,480,4504,4328,596,484,596,1568,600,516,560,1568,604,480,596,1572,596,476,596,500,4484,4360,564,516,564,1572,596,476,600,1628,540,540,536,1576,588,480,600,464,4516,4328,596,484,596,1628,540,484,592,1572,596,484,596,1572,592,536,540};
int idx; // has index in table
//decode_results results;
MySensor gw;
MyMessage msgir(CHILD_1, V_IR_RECEIVE);
void setup()
  irrecv.enableIRIn(); // Start the ir receiver
  gw.begin(incomingMessage,AUTO,true);
  // Send the sketch version information to the gateway and Controller
  gw.sendSketchInfo("IR Transceiver", "1.1");
  // Register a sensors to gw. Use binary light for test purposes.
  gw.present(CHILD_1, S_IR);
  Serial.println("Ready to receive...");
void loop()
  gw.process();
  if (irrecv.GetResults(&decoder)) {
    Hash_Decoder.copyBuf(&decoder);//copy the results to the hash decoder
    Hash_Decoder.decode();
    if (!FindHashInOurTable(Hash_Decoder.hash, &idx)) {
      Serial.print("Unknown IR hash received: ");
      Serial.println(Hash_Decoder.hash, HEX);
      Serial.print("Known IR hash received: ");
      gw.send(msgir.set(Hash_Decoder.hash));
    delay(1000);
    irrecv.resume();
bool FindHashInOurTable(const unsigned long hash, int * idx)
  for (int ii=0; ii<MYCODES_NUM; ii++)
    if (myHashes[ii]==hash)
      * idx = ii; // store index value
      return true;
  return false;
void incomingMessage(const MyMessage &message) {
  // We only expect one type of message from controller. But we better check anyway.
  if (message.type==V_IR_SEND) {
     unsigned long ir_code=(unsigned long)message.getLong();
     Serial.print("Gateway received code: ");
     Serial.println(ir_code, HEX);
     if (FindHashInOurTable(ir_code, &idx)) {
      unsigned int tempdata[24];
      Serial.print("Data to send(");
      Serial.print(idx, HEX);
      Serial.print("): {0x");
      for (int i=0;i<24;i++)
          tempdata[i] = pgm_read_word_near(myCodes[idx] + i);
          Serial.print(tempdata[i], HEX);
          if (i < 23)
            Serial.print(",0x");
            Serial.println("}");
        for (int j=1;j<=4;j++) { //send it multiple times
          irsend.IRsendRaw::send((unsigned int *)tempdata, 24, 38);
          delay(15); //wait 15ms
        delay(3000); //wait 3s
Re: Control your Aldi EasyHome robot vacuum cleaner
Posted: Tuesday 29 March 2016 0:36
by joostnl
Nice work! Can you give some information about the ir hardware your using? I wanna try this on my ilife v7 robot.
Posted: Sunday 03 April 2016 9:13
by curious
I am new to domoticz and investigating the possibilities.Doesn't the ir-sender have to pointed in the direction of ir receiver ??
Posted: Sunday 03 April 2016 16:30
by LouiS22
joostnl wrote:Nice work! Can you give some information about the ir hardware your using? I wanna try this on my ilife v7 robot.
Hi I ordered the exact ones you find @ mysensors.org from aliexpress: http://www.aliexpress.com/item/2PCS-Dig ... a34cc14fe7
Posted: Sunday 03 April 2016 16:31
by LouiS22
curious wrote:I am new to domoticz and investigating the possibilities.Doesn't the ir-sender have to pointed in the direction of ir receiver ??
Yes, that's right.
Posted: Monday 05 September 2016 16:53
by remb0
I want to build it also for my new vacuum cleaner (ilife a4)
are you going to add more controls like: back to base, max cleaning etc?
and are you going to migrate to mysensors 2.0 ?
first: I gonna order the components.
Posted: Wednesday 02 November 2016 9:35
by Kwintessens
remb0 wrote:I want to build it also for my new vacuum cleaner (ilife a4)
Any luck so far? I am orienting at the moment :mrgreen:.
Posted: Monday 04 December 2017 9:47
by Eurovik
Hello!
Nice work!
Unfortunately I do not have my remote control. Can you send the "HOME" and "VIRTUAL WALL" RAW codes?
