Problem Code Blyss
Posted: Monday 14 March 2016 16:37
by ericorso
I come to you because here I am ... more
My Installation!
Raspberry with Domoticz
Arduino Mega with RFLINK R39
I switches Blyss Ref: 582864 and micro receiver Blyss ref 582866
Following the return of the Arduino console.
20; 06; Blyss; ID = 364F; SWITCH = G1; CMD = ON;
20; 07; Blyss; ID = 364F; SWITCH = G1; CMD = OFF;
On the Arduino console, the following commands will work:
10; Blyss; 364F; G1; OFF;
10; Blyss; 364F; G1; ON;
Detection of a switch under Domoticz
62 RFLINK 0000364F 255 Unknown Light / Off Switch Blyss
After creation of an inter here is my log back
Sending RFLink: 10; Blyss; 00364f; ff, ON
Obviously this does not work.
Someone would have any idea.
Thank you.
Bonjour,
Je viens vers vous car là, je suis plus...
Mon Installation !
Raspberry avec Domoticz
Arduino Mega avec RFLINK R39
J'ai des interrupteurs Blyss Réf : 582864 et micro récepteur Blyss réf 582866
Ci-dessous le retour de la console Arduino.
20;06;Blyss;ID=364f;SWITCH=G1;CMD=ON;
20;07;Blyss;ID=364f;SWITCH=G1;CMD=OFF;
Sur la console Arduino, les commandes suivantes fonctionnent très bien :
10;Blyss;364f;G1;OFF;
10;Blyss;364f;G1;ON;
Détection d'un interrupteur sous Domoticz
62 RFLINK 0000364F 255 Unknown Light/Switch Blyss Off
Après création d'un inter voila mon retour de log
RFLink Sending: 10;Blyss;00364f;ff;ON
Évidemment cela ne fonctionne pas.
Quelqu'un aurait une idée.
Merci.
Re: Problem Code Blyss
Posted: Monday 14 March 2016 21:39
by ericorso
Resolved. : Shock:
We must change the basis domoticz.db
Take the free version SQLiteExpertPersSetup program staff. http://www.sqliteexpert.com/download.html
manually creates an ON / OFF Blyss protocol with the correct address, the group code and code regardless of unit with 1.
Domoticz leave and cut server.
Open the database for me it is in C: \ Program Files \ Domoticz (And yes my testes are on Windows)
Take the basic device status
Search DeviceID your Blyss switch (Ref: 582864)
ID like your example 05f3 and 47 05f347
Remove 47 to 193 and in the Unit column.
Close SQLITE and launch Domoticz.
In devices are two Blyss with the same address. We must remove that is is connected to your switch creates the beginning.
It remains only to test the ignition of one rest before adding the new device.
Good luck.
Résolu. :shock:
Il faut modifier la base domoticz.db
Prendre le programme SQLiteExpertPersSetup version gratuit en personnel. http://www.sqliteexpert.com/download.html
Crée manuellement un ON/OFF protocole BLYSS avec la bonne adresse, le code groupe peut importe et code unité avec 1.
Quitter Domoticz et couper le server.
Ouvrir la base pour moi elle est dans C:\Program Files\Domoticz (Et oui mes testes sont sous Windows)
Prendre la base DeviceStatus
Chercher dans DeviceID de votre interrupteur Blyss (Réf : 582864)
ID ressemble à votre exemple 05f3 et 47 05f347
Supprimer le 47 et mettre 193 dans la colonne Unit.
Fermer SQLITE et lancer Domoticz.
Dans dispositifs vous trouverez deux blyss avec la même adresse. Il faut supprimer celui est est en liaison avec votre interrupteur crée au début.
Il reste plus que faire le test d’allumage de celui que reste avant d'ajouter le nouveau dispositif.
Bon courage.
